decode my timeslip #1920942
09/28/15 12:00 AM
09/28/15 12:00 AM
Medina, OH
dart440_72 Offline OP
Medina, OH
So I have been chasing the 10's for years and finally did it!This past Wednesday I went a 10.66 at 124MPH. I think the combo has more in it. I just have to figure it out.
The car is a 72 Dart with a 500" low deck. Indy SR. Solid cam 650ish, 275@50. compression is around 13.5:1. 727 with an 8" converter flashing at 5400. rear gears are 4.33. I'm not sure if that converter is flashing too high. That is what the company recommended.
I also don't have a clue on how to post pics on this site. Not sure if you will be able to view this or not.
Thanks in advance.
[img:left]https://drive.google.com/file/d/0B89l7x47jBZVcU91NU5FVXZrVHc/view?usp=sharing[/img]
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: decode my timeslip [Re: dart440_72] #1920964
09/28/15 12:29 AM
09/28/15 12:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You can compare it to my 10.76 timeslip here from my 63. But I think you have more potential in your car as I am 10.6 comp with less cam and a 9.5 conveter in my pump gas 493. You should be able to tune more out of yours. I am running 4.30's with a 30 x 9 tire. Good luck. Ron
Re: decode my timeslip [Re: dart440_72] #1921094
09/28/15 11:11 AM
09/28/15 11:11 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Looks acceptable up to the 1/8,,,,appears lazy from the 1/8 to the 1/4. Might need more fuel or fuel system upgrades.
If you like drag racing, support your local track.
Re: decode my timeslip [Re: dart440_72] #1921095
09/28/15 11:14 AM
09/28/15 11:14 AM
Az
Crizila Offline
Crizila  Offline
Az
Rear tire diameter at what rpm are you shifting at?
Fastest 300
Re: decode my timeslip [Re: Crizila] #1921098
09/28/15 11:20 AM
09/28/15 11:20 AM
Medina, OH
Medina, OH
Rear tire is a 28x10.5. I was shifting at 6400.
Re: decode my timeslip [Re: dart440_72] #1921102
09/28/15 11:24 AM
09/28/15 11:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
intake and carb?
Re: decode my timeslip [Re: J_BODY] #1921112
09/28/15 11:36 AM
09/28/15 11:36 AM
fullmetaljacket Offline
Like said, a little laid back in the 1/8 zone.
Carb size? shooters? Jets?
Re: decode my timeslip [Re: dart440_72] #1921209
09/28/15 02:57 PM
09/28/15 02:57 PM
I would work on the 60 ft. times, try different stall speeds, air pressures, shock settings and so on up twocents As far as the 1/4 MPH have you tried jetting the carb. up fat enough to slow the MPH down? If not try that, if you can't jet it fat enough to slow the MPH down in the 1/4you need to fix the fuel delivery system scope Let us know what you do and the results work BTW, are your SR 440 port or Max Wedge size? If 440 the porting them to the M.W. size will help also, more air and fuel equals more power thumbs
Re: decode my timeslip [Re: dart440_72] #1921451
09/28/15 08:56 PM
09/28/15 08:56 PM
Medina, OH
Medina, OH
Thanks for all the responses. It really helps! My intake is a 4150 M1 Single plane with a 1000CFM Demon RS on it. Not sure on the jets and squirters. I do know that my AFR is around 11-12:1 from the wideband. I really wanted to confirm that the car had some more in it. It seemed like it did. Now I just have to sort it out.
The heads don't have max wedge ports yet.
Thanks again
Re: decode my timeslip [Re: dart440_72] #1921460
09/28/15 09:16 PM
09/28/15 09:16 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Your 60 ft. should be a lot better. If you get it better you would pick up. My full interior 71 Demon with a stock stroke 360 with ported stock heads with the same gears had a 1.49 60 ft. and ran a best of 6.99 in the 1/8.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: decode my timeslip [Re: dart440_72] #1921466
09/28/15 09:32 PM
09/28/15 09:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks again
At 11-12 on AFR your fat... try leaning it down
EDIT
watch the MPH to get the max MPH when jetting... ET
is the chassis
wave
Re: decode my timeslip [Re: dart440_72] #1921516
09/28/15 11:03 PM
09/28/15 11:03 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I didn't have max ports on my stage VI heads, but switching from a 4150 intake and holley 850 to a 4500 M1 and a Carb Shop 1050 Dominator netted me nearly 4mph. I was running the Ultradyne NF69 mech cam .640 lift and had my shift light set at 5800. I always had good 1/8th mile times, but it seemed A LOT of cars would drive around me on the top end. That changed with the intake/carb swap. It increased airflow so much I had to drop from a 4.56 gear down to a 4.10 to manage the rpms...... and it went quicker yet with the 4.10.
Re: decode my timeslip [Re: dart440_72] #1922921
09/30/15 11:27 PM
09/30/15 11:27 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I have a 850 base 4150 carb with a 950 cfm proform main body....on a Indy headed 408
You really gaine dthat much with a 1050 dominator ?
Tell me more !
Dan
Re: decode my timeslip [Re: dart440_72] #1922933
09/30/15 11:45 PM
09/30/15 11:45 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have a duster with me in it it is 3120lb or so.
i have ported heads though with a 262/265 about 640 lift solid m1 intake and dominator around 13.5 compression aside from the porting we should be able to compare i am only 440 cid i shift at 6700 and go through about that. i am 4.30 gears with 30x10.5 slicks.you are 500 and a cam with more duration. mine is @ 110 centerline.
my converter is a 9" lupo in around 5400 to 5600 flash. 60ft is 1.44 to 1.46
i am around 105 in the 1/8 and 130 in the 1/4 lower 10.20s to teens at numidia pa. really cold air at cecil md 9.89 @134. with 1.39 60ft.
i shoot for 13.3 to 1 on my wego3 wide band afr datalogger.
get a handle on your real afr and if you are in the 11s or low 12 i would say there is room to go faster.
one thing i will say is the afr logger will tell you a lot on what the carb is doing. my carb has issues going leaner around 6300 and then almost 1 point richer at 7000.so reading a plug on top end would make the middle leaner. (i am working on that issue)
