modified stock gas tank #1919391
09/25/15 12:46 PM
09/25/15 12:46 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
anyone have any pics of modified stock tanks to use 8 or 10 AN feed and return?
Re: modified stock gas tank [Re: bonefish] #1919417
09/25/15 01:16 PM
09/25/15 01:16 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
You could use a sump kit welded to the bottom. Use one of the bungs welded on the sump for the supply. Then I would remove the sending unit and weld a bung to that in place of the original pickup tube. You could use the other bung in the sump but I wouldn't want to do that because of the turbulence. My car has the sump but I don't use a return system.....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: modified stock gas tank [Re: bonefish] #1919441
09/25/15 01:40 PM
09/25/15 01:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What year and body style tank...the sump kits work
well and a return up in the front/side corner would
be a good return area... dont use the sump for a return
area... that would be a turbulence and aireation issue
being that its in a confined area(you put a few 1" holes
in the bottom of the tank where the sump mounts)... if you
do use a sump kit.. keep it towards the rear of the tank
and have a few holes just ahead of the rear sump wall ..so
if your low on fuel it will get the most fuel into the sump
Also when you return the fuel have it so the return fuel is
in the fuel(not above the fuel level).. the splash will create
air... I dont have any pics of the stock tanks I use to build
for Chrysler (wasnt allowed to take pics out of work being
that the tanks were pre production stuff)... I can show you my
Rampage tank but its a alum home made item
wave
Re: modified stock gas tank [Re: MR_P_BODY] #1919476
09/25/15 02:15 PM
09/25/15 02:15 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
wave
its a 69 b-body.good idea of drillin the holes,i was gunna just cut it out square upthe return idea makes sense too.
Re: modified stock gas tank [Re: bonefish] #1919549
09/25/15 04:03 PM
09/25/15 04:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
The holes work as a anti slosh so the fuel doesnt
run up the back wall and out if your low on fuel
wave
Re: modified stock gas tank [Re: bonefish] #1919856
09/26/15 12:32 AM
09/26/15 12:32 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run a Comp Engineering sump welded on the stock tank in my 68 Satellite . -8 line out to filter/pump , I run a -6 return line back into a 3/8" sender unit , I did alter sender to not direct returning fuel at the sump .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: modified stock gas tank [Re: bonefish] #1919858
09/26/15 12:39 AM
09/26/15 12:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Year One sell a 1/2 pickup & sender unit that has an extra but small hose port, probably an emissions thing. i plumbed the return from my Magnafuel 275 onto that & changed the mainline to -8 hose. works great on my E body.
