Anyone running a lunati voodoo 704 cam (276/284)? #1911194
09/12/15 06:48 PM
09/12/15 06:48 PM
California
BigDaddy440 Offline OP
California
Originally I was going to use a Bob K Six Pack cam for my new 440, but I'm fearful the six pack cam, while a proven cam, may be a bit mild for me.
I'm looking at the Lunati Voodoo 10230704 cam which is 276/284 advertised and 234/242 @.050 with .513/.533 lift. I'm considering a 1.6 ratio rocker to increase lift a bit as my heads flow well above .500 lift.
Just wondering how others like or dislike the cam. I'm running sidewinder heads with a nice bowl blend, six pack set up, 1 7/8" headers, 4speed, 4.10 gears.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: BigDaddy440] #1911309
09/12/15 10:15 PM
09/12/15 10:15 PM
sweden
carter Offline
carter  Offline
sweden
I run that cam for 4 years in my Eddy headed 383 and a T/A vert whit 3800 stall and 3.91 in the rear in a stock E-body. And i like it, good street manners IMO and has enough vacuum for my stock P/D.
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: BigDaddy440] #1911858
09/13/15 09:28 PM
09/13/15 09:28 PM
California
California
Thanks for your response Carter. I'm just looking for newer tech cam that makes good power from 2500-6000 that is compatible with a 4speed on the street.
Anyone else? Other flat tappet cam suggestions?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: BigDaddy440] #1912189
09/14/15 01:10 PM
09/14/15 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
With a 4-speed you could go w/more duration if you wanted to.......
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: Thumperdart] #1912607
09/14/15 11:15 PM
09/14/15 11:15 PM
California
California
Is this a rule of thumb?
Im really on the fence about a bigger cam. Everyone wants to make a bunch of power, but its important to me that this car is street friendly and drivable with the 4 speed.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: BigDaddy440] #1912738
09/15/15 01:00 AM
09/15/15 01:00 AM
ohio
2
2264PLY Offline
2264PLY  Offline
ohio
I would probably lean towards the shorter duration. I ran the comp cam 305 duration cam in 2 4 speed GTXs with a 3.54 gear and I wasn't happy with the low speed performance. I want to try the shorter duration cam like you mentioned.
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: BigDaddy440] #1912760
09/15/15 01:45 AM
09/15/15 01:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Street friendly is different for different people I guess and if that`s the case then you could go w/less and give up a bit of power for better street ability if that`s what you desire......I like both but understand your needs...... thumbs
Re: Anyone running a lunati voodoo 704 cam (276/284)? [Re: Thumperdart] #1912772
09/15/15 02:10 AM
09/15/15 02:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go with a wider LSA to get a broader torque curve... like
a 112.. with a stick you can change the rpm you leave the
street light or change gears in the rear... I myself dont
like the wide LSA(I had one in my W-9) because you will
loose some bottom end torque.. and it doesnt have the sound
that I like... but with the cubes it should cover up the
low end loss
EDIT
Just put it in at 108 or less
wave
