Block sleeving? Is it a big deal? #190513
01/11/09 02:17 PM
01/11/09 02:17 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I have a 71-Hemi block that has been bored .060 and has been sitting for years. It does have one sleeve in it.
I'm wondering if I should have all the bores sleeved back to standard or if they are good, hone it and go on? This will be for a stock type rebuild.
What are the costs in sleeving?
Re: Block sleeving? Is it a big deal? [Re: cdp] #190514
01/11/09 02:33 PM
01/11/09 02:33 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
about $80-$100 a cylinder
Re: Block sleeving? Is it a big deal? [Re: Defbob] #190515
01/11/09 02:35 PM
01/11/09 02:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
http://www.larryspower.com/engine/DartonSleeves.html
Larry's auto machine does sleeving. This is the machine shop I use
Re: Block sleeving? Is it a big deal? [Re: cdp] #190516
01/11/09 02:52 PM
01/11/09 02:52 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I would get it sonic tested first. If they are thick enough and in good shape I would hone it and go. Second choice would be to bore it .070 over if the walls are thick enough. Third choice would be to sleeve everything. I don't like the idea of sleeving everything because it's such a radical amount of material you're cutting out and replacing but guys have done it with okay results.
Sheldon
Re: Block sleeving? Is it a big deal? [Re: cdp] #190517
01/11/09 02:57 PM
01/11/09 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most likely you can find another block for the price
of sleeving all of them.... unless its a numbers
matching block you are trying to save
Re: Block sleeving? Is it a big deal? [Re: RUNCHARGER] #190518
01/11/09 02:57 PM
01/11/09 02:57 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The place I used to work had a Slant block sleeved on all 6 and charged the customer $800 for it. If they would have asked, I could have given them a good block for $50.
I have no issues with sleeving a rare block like a Hemi, but something common I would not do it.
Re: Block sleeving? Is it a big deal? [Re: slantzilla] #190519
01/11/09 03:03 PM
01/11/09 03:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The Sleeves will probably make the block stronger or as strong as new factory unit. But with all the added costs, You might be better off picking up a new block, but you probably already knew this.
Re: Block sleeving? Is it a big deal? [Re: cdp] #190520
01/11/09 03:32 PM
01/11/09 03:32 PM
an8sec70cuda Offline
Nothing wrong w/ a sleeve if done by a competent machine shop. As said before, it usualy costs around $100 per cylinder.
If your block is good to go as is, then run it at .060" over for now. You can always sleeve it later.
With what hemi blocks are going for now, I doubt very seriously you could find another block in better condition selling for less than it would cost you to sleeve all 8 cylinders on your current block. Another block will probably cost you atleast twice what you'd have in sleeving all 8 holes in your current block. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Block sleeving? Is it a big deal? [Re: cdp] #190521
01/11/09 10:18 PM
01/11/09 10:18 PM
The 1971 blocks are the hardest ones to find, I would E bay it and use that money to buy a new 4.5 bore World block I have built several street Hemi motors that where bored to 4.32 and had custom pistons made for that bore size Way cheaper than having the block sleeved and buying new stndard bore pistons
Re: Block sleeving? Is it a big deal? [Re: Cab_Burge] #190522
01/12/09 06:35 PM
01/12/09 06:35 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I got one(+.070)sitting here now, thats the combo I used to run in my last truck.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
