Re: Block sleeving? Is it a big deal?
[Re: cdp]
#190517
01/11/09 02:57 PM
01/11/09 02:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Most likely you can find another block for the price of sleeving all of them.... unless its a numbers matching block you are trying to save
[Re: cdp]
#190520
01/11/09 03:32 PM
01/11/09 03:32 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Nothing wrong w/ a sleeve if done by a competent machine shop. As said before, it usualy costs around $100 per cylinder. If your block is good to go as is, then run it at .060" over for now. You can always sleeve it later. With what hemi blocks are going for now, I doubt very seriously you could find another block in better condition selling for less than it would cost you to sleeve all 8 cylinders on your current block. Another block will probably cost you atleast twice what you'd have in sleeving all 8 holes in your current block. CHIP
[Re: Cab_Burge]
#190522
01/12/09 06:35 PM
01/12/09 06:35 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
I got one(+.070)sitting here now, thats the combo I used to run in my last truck.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
