70 Coronet R/T - RH inner fender bolt holes - used for? #1901104
08/28/15 02:18 PM
08/28/15 02:18 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
There are 3 holes on the inner fender that are circled in the pic below. Anyone know what they are used for? The LHS does not have all three holes like the RHS.
Thank you in advance for your assistance!
Vinny
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: vinnyd76] #1901112
08/28/15 02:26 PM
08/28/15 02:26 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
fender bolts
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: Bull1tt] #1901115
08/28/15 02:31 PM
08/28/15 02:31 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Originally Posted By Bull1tt
fender bolts
Yep. Behind the headlight area there is a part of the fender that attaches along the inner front with the 3 bolts. IIRC the repro inner fenders do not have the holes punched, so if you have replaced the inner fender from another car or its a repro panel then the holes will not be there.
68 Charger R/T 440 auto
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: Bull1tt] #1901123
08/28/15 02:40 PM
08/28/15 02:40 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
But LHS does not have the same number of slot holes... that is why I was not sure what is secured on that side. I know the horns secure to the rad support.
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: wesgtx440] #1901130
08/28/15 02:44 PM
08/28/15 02:44 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I also looked at a 68 Coronet R/T and they have a pierce nut in those holes. I'm trying to find some older photos to verify, but I thought maybe Chrysler Corp. did not want to change the metal for the new model year and it was just left unused?
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: vinnyd76] #1902040
08/29/15 08:27 PM
08/29/15 08:27 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I have a '70 Superbee and the only hole open is the lowest. The top two are not punched out. Bottom hole has a bolt into a U nut in inner fender brace for bumper bracket.
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: vinnyd76] #1902063
08/29/15 09:09 PM
08/29/15 09:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Mine has three open holes on passenger side - none of them used for anything.
Driver side, bottom hole only, also not used.
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: vinnyd76] #1902700
08/30/15 09:47 PM
08/30/15 09:47 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
There no upper holes on the drivers side?
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: vinnyd76] #1902860
08/31/15 12:26 AM
08/31/15 12:26 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Those holes are actually on/in the rad support. The inner fenders only have the cutouts around the holes. Both sides of the rad support have the same number of holes (3). And the repro rad supports have the same number of holes on both sides as well. If necessary I can post photos of originals and repros ... working on that stuff right now myself. Mine is a '69 RR but the rad supports and inner fenders are the same except for a Charger I believe.
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: Pynzo] #1902862
08/31/15 12:27 AM
08/31/15 12:27 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How are the fenders secured to the car ???
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: vinnyd76] #1902882
08/31/15 12:50 AM
08/31/15 12:50 AM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Must be a production date thing.Only the lower holes are used and the majority of cars i've seen are this way.Rad support part numbers change for the 70 model year...early cars possibly used left over 69 stuff.Other possibility is a car thats been clipped or had a frame rail/inner fender unit swapped in.
"Long Live Mopars"
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: Bull1tt] #1903029
08/31/15 10:44 AM
08/31/15 10:44 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Attached is a photo of the driver's side inner fender prior to the restoration. This evening, I will locate and post a pic that clearly shows the LHS, but for now I located these two pics and there is only one slotted hole that the bottom as opposed to three like the left.
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: Stanton] #1903033
08/31/15 10:57 AM
08/31/15 10:57 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I have an early August '69 Lynch Road build, 26" Radiator Support. The fenders attached at the front of the Rad support. Those holes go into the wheel well.
Pic of front fender mounting bolts.
Re: 70 Coronet R/T - RH inner fender bolt holes - used for? [Re: Pynzo] #1903412
08/31/15 08:07 PM
08/31/15 08:07 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I pulled the horns out to get a clear pic. Inner and outer shots. Nothing in the wheel well to attach with top holes on my '70 Coronet. Bottom bolt into a U nut at the bumper bracket brace. All original sheet metal.
