Re: 70 Coronet R/T - RH inner fender bolt holes - used for?
[Re: vinnyd76]
#1901112
08/28/15 02:26 PM
08/28/15 02:26 PM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
[Re: Bull1tt]
#1901115
08/28/15 02:31 PM
08/28/15 02:31 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
Yep. Behind the headlight area there is a part of the fender that attaches along the inner front with the 3 bolts. IIRC the repro inner fenders do not have the holes punched, so if you have replaced the inner fender from another car or its a repro panel then the holes will not be there.
68 Charger R/T 440 auto
[Re: Pynzo]
#1902862
08/31/15 12:27 AM
08/31/15 12:27 AM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have a '70 Superbee and the only hole open is the lowest. The top two are not punched out. Bottom hole has a bolt into a U nut in inner fender brace for bumper bracket. How are the fenders secured to the car ???
[Re: vinnyd76]
#1902882
08/31/15 12:50 AM
08/31/15 12:50 AM
Posts: 2,601 Great White North
Furyman
Great White North
Must be a production date thing.Only the lower holes are used and the majority of cars i've seen are this way.Rad support part numbers change for the 70 model year...early cars possibly used left over 69 stuff.Other possibility is a car thats been clipped or had a frame rail/inner fender unit swapped in.
"Long Live Mopars"
[Re: Stanton]
#1903033
08/31/15 10:57 AM
08/31/15 10:57 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
I have a '70 Superbee and the only hole open is the lowest. The top two are not punched out. Bottom hole has a bolt into a U nut in inner fender brace for bumper bracket. How are the fenders secured to the car ??? I have an early August '69 Lynch Road build, 26" Radiator Support. The fenders attached at the front of the Rad support. Those holes go into the wheel well. Pic of front fender mounting bolts.
