Power Steering Leak
#1892472
08/15/15 04:26 PM
08/15/15 04:26 PM
Posts: 234 London, England
JFChallenger440
London, England
69 Coronet, 383 On full lock the power steering fluid is spraying out 1 side of the cap, I turned the cap the other way round and the spray is coming from the other side so it's obviously only 1 side of the cap that is the problem, is it a case of of just replacing the cap or is there anything else I can look for ? The seal looks ok on it, not sure if you can tell from the below pic, if I need to order a cap is there any particular one I need to get as I couldn't see any numbers on it ? The pump has some numbers on it, see below, also it says vented on the cap but where exactly is it venting as I can't see any holes, I assume the grooves are the vents ? Thanks
Re: Power Steering Leak
[Re: JFChallenger440]
#1893776
08/17/15 07:11 PM
08/17/15 07:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looks like a cap for a Federal pump, not a Saginaw. Not available new, just NOS and used. https://www.jimsautoparts.com/steering_parts.htmScroll down you'll see it, not cheap at all.
#1893847
08/17/15 08:44 PM
08/17/15 08:44 PM
Supercuda
About to go away
About to go away
up yours
Wasn't recommending Jim's, just showing it's there and it's not cheap.
#1894235
08/18/15 10:28 AM
08/18/15 10:28 AM
Supercuda
About to go away
About to go away
up yours
I read a thread on FABO that someone was able to use a seal from a gas cap they had lying around to fix this problem. No more info than that though. You might take the cap to the parts store and see if any of the gas caps there could be a donor. Or you could go here and see if anything will work http://www.bestmaterials.com/sealing_washer.aspx
