Power Steering Leak #1892472
08/15/15 04:26 PM
08/15/15 04:26 PM
London, England
JFChallenger440 Offline OP
London, England
69 Coronet, 383
On full lock the power steering fluid is spraying out 1 side of the cap, I turned the cap the other way round and the spray is coming from the other side so it's obviously only 1 side of the cap that is the problem, is it a case of of just replacing the cap or is there anything else I can look for ? The seal looks ok on it, not sure if you can tell from the below pic, if I need to order a cap is there any particular one I need to get as I couldn't see any numbers on it ? The pump has some numbers on it, see below, also it says vented on the cap but where exactly is it venting as I can't see any holes, I assume the grooves are the vents ? Thanks
Re: Power Steering Leak [Re: JFChallenger440] #1892475
08/15/15 04:30 PM
08/15/15 04:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like it might be over filled. I hope you're not holding it at full lock for long.
Re: Power Steering Leak [Re: stumpy] #1893446
08/17/15 06:39 AM
08/17/15 06:39 AM
London, England
London, England
Thanks but it wasn't reading anything on the dipstick so was low if anything, i'll probably try a new cap or gasket first, any idea what cap I need and where to get one ? Thanks
Re: Power Steering Leak [Re: JFChallenger440] #1893455
08/17/15 08:52 AM
08/17/15 08:52 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that doesn't look like a power steering cap. more like a gas tank cap. not sure what you have on your side of the pond but an auto parts store might have what you need. i know Classic Industries has the correct one.
Re: Power Steering Leak [Re: mikemee1331] #1893462
08/17/15 10:01 AM
08/17/15 10:01 AM
London, England
London, England
It has the dipstick attached to it though so I assume it's a power steering cap for something, i'll try and order the correct cap, thanks
Re: Power Steering Leak [Re: JFChallenger440] #1893523
08/17/15 12:33 PM
08/17/15 12:33 PM
London, England
London, England
Anyone know what cap I should order ? Classic Industries only have a cap for a Saginaw pump, pretty sure I don't have one of them
Re: Power Steering Leak [Re: JFChallenger440] #1893776
08/17/15 07:11 PM
08/17/15 07:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks like a cap for a Federal pump, not a Saginaw. Not available new, just NOS and used.
https://www.jimsautoparts.com/steering_parts.htm
Scroll down you'll see it, not cheap at all.
Don't be the exception.
Re: Power Steering Leak [Re: JFChallenger440] #1893791
08/17/15 07:25 PM
08/17/15 07:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Warning!! warning!! stay away from Jim's if you value your time and money. Do a search here and see how many people had nothing but bad interaction with Jim's. One of the worst reputations among Mopar parts vendors.
Re: Power Steering Leak [Re: JFChallenger440] #1893847
08/17/15 08:44 PM
08/17/15 08:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wasn't recommending Jim's, just showing it's there and it's not cheap.
Re: Power Steering Leak [Re: Supercuda] #1893913
08/17/15 09:49 PM
08/17/15 09:49 PM
London, England
London, England
Anything else I can try to stop it leaking ? Thought about fitting a better homemade rubber seal to it or something ?
Re: Power Steering Leak [Re: JFChallenger440] #1894235
08/18/15 10:28 AM
08/18/15 10:28 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I read a thread on FABO that someone was able to use a seal from a gas cap they had lying around to fix this problem. No more info than that though. You might take the cap to the parts store and see if any of the gas caps there could be a donor. Or you could go here and see if anything will work
http://www.bestmaterials.com/sealing_washer.aspx
Re: Power Steering Leak [Re: JFChallenger440] #1894811
08/18/15 09:42 PM
08/18/15 09:42 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I guess we can assume that this pump has been in use on the car for sometime and that this a recent problem. If not the case, was it properly bled to remove all air bubbles after installation?
Possible bad valve or spring in pump creating excessive pressure. Believe there are tools to measure pressure.
