Re: pertronix igniter III
[Re: JohnRR]
#1890400
08/12/15 05:43 PM
08/12/15 05:43 PM
Posts: 4,179 California
mickm
California
I didn't think they had one for the prestolite ? i haven't double checked, but it is listed as all models from 64-72, something like that.
[Re: mickm]
#1890695
08/13/15 12:23 AM
08/13/15 12:23 AM
RapidRobert
I have a new one (P 111) and a point dist & some Lowes bushings and a Grainger 15/32-17/32 adjustable reamer, I just ain't got to it yet
[Re: mickm]
#1891176
08/13/15 06:18 PM
08/13/15 06:18 PM
Posts: 45 Georgia
1969383S
Georgia
I am currently running the III with the correct III coil and Taylor 8MM Street Thunder Suppressor wires.
It appears to be just fine. I replaced a Mopar electronic ignition with gold box.
I like that it is all hidden with no extras harness short of the one extra wire from the dizzy. I heat shrinked them together so it looks like one at first glance. I took an extra ballast and opened the back and replaced the windings with a solid piece of #12 copper.(The Look I wanted was stock appearing)
Been running since late last year and other than having to re-curve the point type dizzy I decided to use, there have been no issues and as good or better than the old electronic. My plugs look better than they ever have.
Just make sure and use all the correct components recommended by Pertronix.
Gerald
[Re: 1969383S]
#1891198
08/13/15 07:07 PM
08/13/15 07:07 PM
mickm
California
Just make sure and use all the correct components recommended by Pertronix. that sounds great! i'm going for a very stock look as well, (hence rebuilding the prestolite), and would love to do that. good info about the ballast, thanks. and the tip about current components. i'm not thrilled about the rev limiter not being a soft type, but can live with that. i'll post if/when i make the conversion.
[Re: 1969383S]
#1891580
08/14/15 02:53 AM
08/14/15 02:53 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Just make sure and use all the correct components recommended by Pertronix. What distributor are you running it in ? When I did a search on the pertronics website it doesn't show the III with any prestolite numbers .
[Re: JohnRR]
#1891854
08/14/15 02:45 PM
08/14/15 02:45 PM
mickm
California
it is a prestolite. i haven't plugged in the number yet, i will do that this weekend. if it doesn't fit, well, that takes care of that, but it did say all distributors 62-71 or something like that.
