pertronix igniter III #1890344
08/12/15 04:19 PM
08/12/15 04:19 PM
California
mickm Offline OP
mickm  Offline OP
California
anyone have any experience with this? from the description on the page, it sounds like an awesome unit, doing most or all of what an MSD box does. if that's the case, i'd rather run that than the MSD box. i also like it because it will allow me to run the prestolite distributor i have, giving the engine a stock look, but still give me a rev limiter.
it supposedly does multiple spark, so i'm not sure what is needed for a tach hookup, but it does look pretty cool.
Re: pertronix igniter III [Re: mickm] #1890363
08/12/15 04:50 PM
08/12/15 04:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't think they had one for the prestolite ?
Re: pertronix igniter III [Re: JohnRR] #1890400
08/12/15 05:43 PM
08/12/15 05:43 PM
California
mickm Offline OP
mickm  Offline OP
California
i haven't double checked, but it is listed as all models from 64-72, something like that.
Re: pertronix igniter III [Re: mickm] #1890695
08/13/15 12:23 AM
08/13/15 12:23 AM
I have a new one (P 111) and a point dist & some Lowes bushings and a Grainger 15/32-17/32 adjustable reamer, I just ain't got to it yet
Re: pertronix igniter III [Re: RapidRobert] #1890821
08/13/15 08:02 AM
08/13/15 08:02 AM
SE PA
Yellow Fever Offline
SE PA
I have a billet Pertronix III distributor and it's great! The rev limiter works, hit it a few times. I need to set it higher, left it on default rpm until after break-in.
drive
As long as their unit fits I say go for it.
Re: pertronix igniter III [Re: Yellow Fever] #1890823
08/13/15 08:07 AM
08/13/15 08:07 AM
SE PA
SE PA
1959-71 V8 383-440 cid. engine (including Hemi) Auto/Prestolite
10, 79
71385
10 Dual point distributor
79 Not for use with solid core spark plug wires
http://www.pertronix.com/catalogs/pdf/ptx/2015/Pertronix2015.pdf
Re: pertronix igniter III [Re: Yellow Fever] #1890824
08/13/15 08:10 AM
08/13/15 08:10 AM
SE PA
SE PA
Re: pertronix igniter III [Re: Yellow Fever] #1891081
08/13/15 04:27 PM
08/13/15 04:27 PM
California
mickm Offline OP
mickm  Offline OP
California
good information, but i was hoping to find someone who has used it. i'm really thinking of doing this and getting rid of the MSD.
i know modern electronics are incredible in space savings, but it's hard to imagine how they get most or all of what is going on in an MSD box into that little container.
Re: pertronix igniter III [Re: mickm] #1891169
08/13/15 06:14 PM
08/13/15 06:14 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
a friend has one on his 427 vette. seems to work fine. the rev limiter is not a soft touch. hit the limit and the engine quits. for me, i want to try the new fbo unit. simple plug in with mopar harness and you can carry an inexpensive auto store box in the trunk for a spare; something that can't be done with pertronix or msd.
Re: pertronix igniter III [Re: mickm] #1891176
08/13/15 06:18 PM
08/13/15 06:18 PM
Georgia
1969383S Offline
1969383S  Offline
Georgia
I am currently running the III with the correct III coil and Taylor 8MM Street Thunder Suppressor wires.
It appears to be just fine. I replaced a Mopar electronic ignition with gold box.
I like that it is all hidden with no extras harness short of the one extra wire from the dizzy. I heat shrinked them together so it looks like one at first glance. I took an extra ballast and opened the back and replaced the windings with a solid piece of #12 copper.(The Look I wanted was stock appearing)
Been running since late last year and other than having to re-curve the point type dizzy I decided to use, there have been no issues and as good or better than the old electronic. My plugs look better than they ever have.
Just make sure and use all the correct components recommended by Pertronix.
Gerald
Re: pertronix igniter III [Re: 1969383S] #1891198
08/13/15 07:07 PM
08/13/15 07:07 PM
California
mickm Offline OP
mickm  Offline OP
California
that sounds great! i'm going for a very stock look as well, (hence rebuilding the prestolite), and would love to do that. good info about the ballast, thanks. and the tip about current components.
i'm not thrilled about the rev limiter not being a soft type, but can live with that.
i'll post if/when i make the conversion.
Re: pertronix igniter III [Re: 1969383S] #1891580
08/14/15 02:53 AM
08/14/15 02:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What distributor are you running it in ? When I did a search on the pertronics website it doesn't show the III with any prestolite numbers .
Re: pertronix igniter III [Re: JohnRR] #1891854
08/14/15 02:45 PM
08/14/15 02:45 PM
California
mickm Offline OP
mickm  Offline OP
California
it is a prestolite. i haven't plugged in the number yet, i will do that this weekend. if it doesn't fit, well, that takes care of that, but it did say all distributors 62-71 or something like that.
