adjusting the turn signal steering wheel tang #1888468
08/09/15 11:54 PM
08/09/15 11:54 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Can anyone explain to me how to position the turn signal tang on my 71 Charger r/t w/tuff wheel? I've tried and tried and I never quite get it in the right place to cancel the turn signal after making a turn. Mechanically everything is there and in working order. I just can't get them to do their job correctly and at the correct time.
Re: adjusting the turn signal steering wheel tang [Re: attaboy] #1888476
08/10/15 12:05 AM
08/10/15 12:05 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Are you sure the cancel cam isn't just worn out? I didn't know you could adjust them. I've only seen signal switches and cancel cams that can only be screwed down in one position.
Facts are stubborn things.
Re: adjusting the turn signal steering wheel tang [Re: larrymopar360] #1888561
08/10/15 02:19 AM
08/10/15 02:19 AM
What larry said, look again & see what is broken/missing likely on the plastic "cam". there's a tab that kicks it back off as you come back to center/straight ahead
Re: adjusting the turn signal steering wheel tang [Re: attaboy] #1888648
08/10/15 10:40 AM
08/10/15 10:40 AM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Depending on the application, there may be an adjustment. On my 65 Polara w/tilt column, there's a fairly heavy snap ring with a protruding tab that cancels the turn signals and it can need adjustment. I had to mess with mine quite a while to get it right when I changed steering wheels.
Mike
Re: adjusting the turn signal steering wheel tang [Re: 1E2C] #1888742
08/10/15 01:26 PM
08/10/15 01:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The canceller tang should be directly opposite the center of the turn signal switch IE: 180 degrees twocents
Re: adjusting the turn signal steering wheel tang [Re: attaboy] #1888983
08/10/15 06:41 PM
08/10/15 06:41 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Turn signal mech. is new Mopar brand. Nothing wrong with it
Re: adjusting the turn signal steering wheel tang [Re: 1E2C] #1888986
08/10/15 06:44 PM
08/10/15 06:44 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
This is what I'm talking about! At what position is this "tang" positioned when the steering wheel is in the normal straight position?
Re: adjusting the turn signal steering wheel tang [Re: TJP] #1888989
08/10/15 06:48 PM
08/10/15 06:48 PM
New Mexico, USA
attaboy Offline OP
attaboy  Offline OP
New Mexico, USA
Hurray, this is the answer I was looking for. Now I know where I need to adjust it to! I really appreciate this. It's been bugging me for several years because it would leave the signal flashing after the wheel returned to the straight ahead position and I'd have manually put the lever back in the neutral position after each turn.
Re: adjusting the turn signal steering wheel tang [Re: attaboy] #1889612
08/11/15 05:45 PM
08/11/15 05:45 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The tuff wheel crush can is indexed too, right, like it can only go on one way due to a big keyway tang in it to mesh with the steering shaft? I have a similar issue after adding a tuff wheel to a 75 A body. Will have to investigate this...
Re: adjusting the turn signal steering wheel tang [Re: attaboy] #1890082
08/12/15 07:39 AM
08/12/15 07:39 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Check out this thread in particular entry 229568 on how I found a simple way to adjust it once you determine where it should be positioned.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/8242588/site_id/1#import
