Re: adjusting the turn signal steering wheel tang
[Re: attaboy]
#1888476
08/10/15 12:05 AM
08/10/15 12:05 AM
Posts: 15,905 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Are you sure the cancel cam isn't just worn out? I didn't know you could adjust them. I've only seen signal switches and cancel cams that can only be screwed down in one position.
Facts are stubborn things.
[Re: larrymopar360]
#1888561
08/10/15 02:19 AM
08/10/15 02:19 AM
RapidRobert
What larry said, look again & see what is broken/missing likely on the plastic "cam". there's a tab that kicks it back off as you come back to center/straight ahead
