which intake to what motor should I use? #188853
01/09/09 08:57 PM
01/09/09 08:57 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
alright, I have 2 intakes and 2 small block motors being built. the intakes are edelbrock LD340 and edelbrock performer RPM. motor #1 is a warmed up 318. 302 heads, mild cam, headers, ect. motor #2 is going to be a stock appearing (FAST) 416. as of now, the 416 is going to have worked over J heads and a streetable cam. which intake would be better for each motor? any ideas? not sure if I needed to give more info. thanks in advance!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: which intake to what motor should I use? [Re: mopars_1] #188854
01/09/09 09:34 PM
01/09/09 09:34 PM
the performer on #1 & the LD340 on #2
Re: which intake to what motor should I use? [Re: RapidRobert] #188855
01/09/09 09:43 PM
01/09/09 09:43 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
any particular reason why? im just curious. thanks!
1937 Plymouth PT50
Re: which intake to what motor should I use? [Re: mopars_1] #188856
01/09/09 09:51 PM
01/09/09 09:51 PM
The performer is pretty much a slightly warmed over stock intake but in aluminum. & also I would check your port matchup as in some intakes have smaller 318 sized ports & others larger 340/360 ports.
Re: which intake to what motor should I use? [Re: RapidRobert] #188857
01/09/09 10:12 PM
01/09/09 10:12 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
correct me if Im wrong, but arn't the LD340 intake pretty close to the stock 340 intakes? I thought I heard that somewhere. btw, im 99% sure both intakes have the larger ports. thanks!
1937 Plymouth PT50
Re: which intake to what motor should I use? [Re: mopars_1] #188858
01/09/09 10:18 PM
01/09/09 10:18 PM
Central NC
gch Offline
gch  Offline
Central NC
I am not a small block guy but from what I have read they are both good intakes.I don't think either one will perform badly in either application.
The ld340 will look more stock for the FAST MOTOR.
Aside from that I can't say.
Re: which intake to what motor should I use? [Re: mopars_1] #188859
01/10/09 09:43 AM
01/10/09 09:43 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
The LD340 is far above the stock or the Performer intakes. No comparison. They are by far closer to the the Airgap and RPM than to the stock or Performer intake if you want to compare them to something.
Re: which intake to what motor should I use? [Re: mopars_1] #188860
01/10/09 10:45 AM
01/10/09 10:45 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Neither are FAST legal. If you mean max performance and kinda stock looking, put the LD340 on the 416
Re: which intake to what motor should I use? [Re: BSB67] #188861
01/10/09 11:46 AM
01/10/09 11:46 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I guess thats what I meant. lol. thanks for all of your help! btw, what would be considered legal for FAST? thanks!
-kevin
1937 Plymouth PT50
Re: which intake to what motor should I use? [Re: mopars_1] #188862
01/10/09 12:19 PM
01/10/09 12:19 PM
Central NC
gch Offline
gch  Offline
Central NC
Factory intake.
Re: which intake to what motor should I use? [Re: gch] #188863
01/10/09 01:09 PM
01/10/09 01:09 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Factory intake.
....with the correct casting numbers for the year.
Re: which intake to what motor should I use? [Re: BSB67] #188864
01/10/09 01:42 PM
01/10/09 01:42 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
alright, I guess I shoulda knew that. I though maybe there were some aluminum intakes that were acceptable. thanks!
-kevin
1937 Plymouth PT50
