which intake to what motor should I use?
#188853
01/09/09 08:57 PM
01/09/09 08:57 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
alright, I have 2 intakes and 2 small block motors being built. the intakes are edelbrock LD340 and edelbrock performer RPM. motor #1 is a warmed up 318. 302 heads, mild cam, headers, ect. motor #2 is going to be a stock appearing (FAST) 416. as of now, the 416 is going to have worked over J heads and a streetable cam. which intake would be better for each motor? any ideas? not sure if I needed to give more info. thanks in advance! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: which intake to what motor should I use?
[Re: mopars_1]
#188854
01/09/09 09:34 PM
01/09/09 09:34 PM
RapidRobert
the performer on #1 & the LD340 on #2
[Re: RapidRobert]
#188855
01/09/09 09:43 PM
01/09/09 09:43 PM
mopars_1
Ridgeland Wi
any particular reason why? im just curious. thanks!
[Re: mopars_1]
#188856
01/09/09 09:51 PM
01/09/09 09:51 PM
RapidRobert
The performer is pretty much a slightly warmed over stock intake but in aluminum. & also I would check your port matchup as in some intakes have smaller 318 sized ports & others larger 340/360 ports.
[Re: RapidRobert]
#188857
01/09/09 10:12 PM
01/09/09 10:12 PM
mopars_1
Ridgeland Wi
correct me if Im wrong, but arn't the LD340 intake pretty close to the stock 340 intakes? I thought I heard that somewhere. btw, im 99% sure both intakes have the larger ports. thanks!
[Re: mopars_1]
#188859
01/10/09 09:43 AM
01/10/09 09:43 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The LD340 is far above the stock or the Performer intakes. No comparison. They are by far closer to the the Airgap and RPM than to the stock or Performer intake if you want to compare them to something.
[Re: gch]
#188863
01/10/09 01:09 PM
01/10/09 01:09 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Factory intake.
....with the correct casting numbers for the year.
[Re: BSB67]
#188864
01/10/09 01:42 PM
01/10/09 01:42 PM
mopars_1
Ridgeland Wi
alright, I guess I shoulda knew that. I though maybe there were some aluminum intakes that were acceptable. thanks! -kevin
