e body rear tire size #1884033
08/03/15 01:29 AM
08/03/15 01:29 AM
Detroit, MI. area
DEERLODGE Offline OP
Detroit, MI. area
Can I get 295/50 15 on the rear of a 1971 challenger 4.5 backspace on 15x8 rims? Thanks
Re: e body rear tire size [Re: DEERLODGE] #1884289
08/03/15 01:59 PM
08/03/15 01:59 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Yes, but you have to run them at lower inflation pressures (25-28)to get full tread contact. Lower pressure leads to greater deflection when cornering and increased heat while driving. Heat is a big factor in the tire carcass degrading so it is by no means an optimal set up. The flip side is to run them at higher pressure (28-32)and wear out the center of the tires because of all the crown you get from putting them on too narrow a rim.
Re: e body rear tire size [Re: DEERLODGE] #1884425
08/03/15 04:44 PM
08/03/15 04:44 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
What rear end do you have?
Re: e body rear tire size [Re: cruzin] #1884599
08/03/15 09:16 PM
08/03/15 09:16 PM
Detroit, MI. area
Detroit, MI. area
Factory 3.23 posi rear end. I've used these tires on 8" rims before on my 71 Road runner with no issues. The tires are spec'd for an 8-10" rim, so I'm fine with the rim size. I'm just not sure if the wheel well is same from the E body vs B as far as being able to tuck these in?
Re: e body rear tire size [Re: DEERLODGE] #1884631
08/03/15 09:51 PM
08/03/15 09:51 PM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
On my '73 challenger I ran a 295/50 15 t/a, 8" wheel with 4" b/s, stock rear end. Couldn't fit my fingers between the tire and the springs or the wheelwell lip. And they'd rub on both when cornering, especially with anyone in the back seat. Stock springs, probably sagged a bit, but not too low. Finally took them off and went with a narrower tire.
Re: e body rear tire size [Re: DEERLODGE] #1884736
08/04/15 12:14 AM
08/04/15 12:14 AM
Detroit, MI. area
Detroit, MI. area
Thank you, that's what I was looking for!
I may have to do a 3/4" spring off-set and run a different backspaced rim...
Re: e body rear tire size [Re: DEERLODGE] #1884796
08/04/15 02:32 AM
08/04/15 02:32 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Get the relocation kit from dr diff and run a b body rearend. It's a bolt in and with a 10" rim with 5.5" back space you can run that tire easy! I have 325-50's under my cuda with this setup and rolled fender lips.
Re: e body rear tire size [Re: barracuda7199] #1885223
08/04/15 10:06 PM
08/04/15 10:06 PM
Earth
Rob C Offline
Rob C  Offline
Earth
What year B body rear?
Re: e body rear tire size [Re: DEERLODGE] #1885257
08/04/15 11:10 PM
08/04/15 11:10 PM
GEORGIA
GEORGIA
68-70
Re: e body rear tire size [Re: DEERLODGE] #1887524
08/08/15 03:49 PM
08/08/15 03:49 PM
Detroit, MI. area
Detroit, MI. area
Thank you, great information.
Re: e body rear tire size [Re: DEERLODGE] #1891528
08/14/15 01:22 AM
08/14/15 01:22 AM
Detroit, MI. area
Detroit, MI. area
I had the BFG's 295/50 15s mounted and put on my 71 e-body. Fit with plenty of room to the springs and the wheel lip. Keeping the rear of the car some what solid though so there is no chance of a rubbing.
Very satisfied with the fit. Rims are 15x8 4.5 offset
Re: e body rear tire size [Re: DEERLODGE] #1892334
08/15/15 12:13 PM
08/15/15 12:13 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Deerlodge, what springs did you have? And do you have a picture by chance?
Re: e body rear tire size [Re: DEERLODGE] #1892683
08/15/15 11:25 PM
08/15/15 11:25 PM
Detroit, MI. area
Detroit, MI. area
Stock hemi style springs. I'll try to get a pick to post.
Re: e body rear tire size [Re: DEERLODGE] #1900373
08/27/15 01:19 PM
08/27/15 01:19 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Deerlodge, Any luck on that pic?
Re: e body rear tire size [Re: DEERLODGE] #1900898
08/28/15 04:35 AM
08/28/15 04:35 AM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
295 50 15 is a little too wide to run on an 8" wide rim.
