Re: e body rear tire size
[Re: cruzin]
#1884599
08/03/15 09:16 PM
08/03/15 09:16 PM
Posts: 48 Detroit, MI. area
DEERLODGE
Detroit, MI. area
Factory 3.23 posi rear end. I've used these tires on 8" rims before on my 71 Road runner with no issues. The tires are spec'd for an 8-10" rim, so I'm fine with the rim size. I'm just not sure if the wheel well is same from the E body vs B as far as being able to tuck these in? Thanks
[Re: barracuda7199]
#1885223
08/04/15 10:06 PM
08/04/15 10:06 PM
Posts: 792 Earth
Rob C
Earth
Get the relocation kit from dr diff and run a b body rearend. It's a bolt in and with a 10" rim with 5.5" back space you can run that tire easy! I have 325-50's under my cuda with this setup and rolled fender lips. What year B body rear?
