converter balance weights?
#1882900
08/01/15 03:20 PM
08/01/15 03:20 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
Just had a new motor built, its internal balanced. balancer has no weights added. Motor was installed by others. previous motor was stock rotating assembly so converter has weights. Do i need to remove the converter weights before I run/drive or wait to see if there is vibrations. Motor is built high HP and RPM.
4bbl
If you can't hear it coming what's the point.......
Re: converter balance weights?
[Re: 4bbl]
#1882919
08/01/15 04:08 PM
08/01/15 04:08 PM
Posts: 7,506 Az
Crizila
Az
Gotta remove the weights from the convertor and run a flex plate and damper for an internal balance motor.
Fastest 300
[Re: Crizila]
#1882986
08/01/15 05:58 PM
08/01/15 05:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Gotta remove the weights from the convertor and run a flex plate and damper for an internal balance motor. Yep.. knock the weight off the conv and change to a zero flex plate EDIT Also check the balancer for no extra weight
[Re: 4bbl]
#1883039
08/01/15 07:18 PM
08/01/15 07:18 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do i need to remove the converter weights before I run/drive or wait to see if there is vibrations. Depends on where the weights are located; thin weights on the outer periphery are for mass balancing and must stay in place but weights on the engine side of the converter are for external balancing...those must be removed.
[Re: 4bbl]
#1883562
08/02/15 03:04 PM
08/02/15 03:04 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
B & M Zero balance flex plate .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
