Best Timing Chain #188229
01/09/09 12:01 AM
01/09/09 12:01 AM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
Who makes the strongest timing chain? I know there are a few billet pieces, does anyone on moparts make them?
Re: Best Timing Chain [Re: joshking440] #188230
01/09/09 09:36 AM
01/09/09 09:36 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i returned the billet Summit brand with the 6 or 9 keyways cause it was was too loose. i end up using a cloyes I had in my parts box
Re: Best Timing Chain [Re: aarcuda] #188231
01/09/09 10:01 AM
01/09/09 10:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd have to say Cloyes are one of the better chain sets
Re: Best Timing Chain [Re: joshking440] #188232
01/09/09 10:17 AM
01/09/09 10:17 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I like the Pro-Gear brand that Hughes Engines sells. (Ya' hear that, Kevin? ) They're available in both standard dimension and .005"-shorter sets.
I had to use the .005"-shorter to take up the chain slack w/ my block because it had been align-bored when fitted for aftermarket caps.
Re: Best Timing Chain [Re: BradH] #188233
01/09/09 10:44 AM
01/09/09 10:44 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'd prefer the manufacturer had left the multiple
keyways in the crank gear though.
Re: Best Timing Chain [Re: BradH] #188234
01/09/09 04:44 PM
01/09/09 04:44 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
The Pro-Gears are the only brand we use or sell in our shop. I won't do a sales pitch here for them but we have never found a chain and gear set that held up better. If you want more details on them call us or check out our website. I have oval track guys running them 4 and 5 seasons and telling me they are as tight as the day they put them on.
p.s. Brad, Thanks for the plug!
Kevin @ Hughes
Re: Best Timing Chain [Re: Hughes] #188235
01/09/09 05:39 PM
01/09/09 05:39 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I also almost exclusively ( use some Cloyes Hex Adjust too) use the Pro Gear. Quality pieces and good people to deal with. Highly recommend them as well.
RIP Monte Smith
Re: Best Timing Chain [Re: CompWedgeEngines] #188236
01/09/09 05:42 PM
01/09/09 05:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Then why is it I've emailed the Tech dept & left voice messages (Mike)& haven't been able to get any response???
Re: Best Timing Chain [Re: 1_WILD_RT] #188237
01/09/09 06:04 PM
01/09/09 06:04 PM
an8sec70cuda Offline
Pro Gear is the nicest I've seen. I had a Cloyes Hexadjust in my hemi for the first 2 years...when I tore it down for freshen up, the center links were breaking on the chain. Cloyes no longer uses an American made chain on their timing sets, some offshore crap that doesn't hold up. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best Timing Chain [Re: 1_WILD_RT] #188238
01/09/09 06:15 PM
01/09/09 06:15 PM
Syracuse,NY
Syracuse,NY
I obviously cant answer that. I deal directly with the owner and I can guarantee you I can get whatever answer you need.
I am sure Kevin or Dave can as well.
How can I help?
RIP Monte Smith
Re: Best Timing Chain [Re: CompWedgeEngines] #188239
01/09/09 06:21 PM
01/09/09 06:21 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I had good luck with the Summit brand. I had the engine tore down after about 50 runs, messing with the cam, and the chain was still tight. It was made by D.I.D. I believe a Japan based company which does make high quality chains..I have had experience with these in my dirt bike days..they always was good products, and took a beating.
Re: Best Timing Chain [Re: Bob_Coomer] #188240
01/09/09 10:22 PM
01/09/09 10:22 PM
Central NC
gch Offline
gch  Offline
Central NC
I have had good service from the rollmaster billet chain I purchased from Hensley years ago.Still in service to this day.I believe they are(were)made in Australia.
Re: Best Timing Chain [Re: gch] #188241
01/09/09 11:40 PM
01/09/09 11:40 PM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
They still are made over here,Rollmaster race proven for over twenty years. Best in the business.
Re: Best Timing Chain [Re: 572B1] #188242
01/10/09 12:21 AM
01/10/09 12:21 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Rollmaster here too.
Nautilus Racing-
Re: Best Timing Chain [Re: Chris2581] #188243
01/10/09 12:42 AM
01/10/09 12:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have the 440 source billit with torrington thrust washer and the optional rolon chain and it fits really well. No miles on it so far.
Not sure where the source gets these from, but the billit Cloyes is not much more expensive?
The 360 LA emgine has the standard Cloyes timming set, but I added the magnum chain tensioner to pick up any slack.
Re: Best Timing Chain [Re: 451Mopar] #188244
01/10/09 12:57 AM
01/10/09 12:57 AM
Brisbane Australia
Brisbane Australia
Rolon is a poor quality chain. Rollmaster premium sets come with Iwis chain from Germany.The cheaper timing sets for std motors come with rolon chains. Rollmaster tested numerous chains and found Iwis in germany to make the best quality chains.I guess he got it right as Crane cams in the usa market rollmaster as there own brand.
Re: Best Timing Chain [Re: 451Mopar] #188245
01/10/09 12:59 AM
01/10/09 12:59 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Cloyes in both C's here.
With over two tons o fun,and a heavy foot,it is my preference.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Best Timing Chain [Re: Hughes] #188246
01/10/09 01:55 AM
01/10/09 01:55 AM
Oak Harbor, WA
W
Wicked49670dart Online mad
Wicked49670dart  Online Mad
W
Oak Harbor, WA
I have used the Pro-Gear chain from Hughes also along with all their valve train parts. Thanks Kevin and Dave...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Best Timing Chain [Re: Wicked49670dart] #188247
01/10/09 12:01 PM
01/10/09 12:01 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
is there a limit on horsepower when using one of these?
Re: Best Timing Chain [Re: joshking440] #188248
01/10/09 05:18 PM
01/10/09 05:18 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
