Re: Best Timing Chain
[Re: joshking440]
#188232
01/09/09 10:17 AM
01/09/09 10:17 AM
BradH
I like the Pro-Gear brand that Hughes Engines sells. (Ya' hear that, Kevin? ) They're available in both standard dimension and .005"-shorter sets. I had to use the .005"-shorter to take up the chain slack w/ my block because it had been align-bored when fitted for aftermarket caps.
[Re: Hughes]
#188235
01/09/09 05:39 PM
01/09/09 05:39 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I also almost exclusively ( use some Cloyes Hex Adjust too) use the Pro Gear. Quality pieces and good people to deal with. Highly recommend them as well.
RIP Monte Smith
[Re: CompWedgeEngines]
#188236
01/09/09 05:42 PM
01/09/09 05:42 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Then why is it I've emailed the Tech dept & left voice messages (Mike)& haven't been able to get any response???
[Re: 1_WILD_RT]
#188237
01/09/09 06:04 PM
01/09/09 06:04 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Pro Gear is the nicest I've seen. I had a Cloyes Hexadjust in my hemi for the first 2 years...when I tore it down for freshen up, the center links were breaking on the chain. Cloyes no longer uses an American made chain on their timing sets, some offshore crap that doesn't hold up. CHIP
[Re: 1_WILD_RT]
#188238
01/09/09 06:15 PM
01/09/09 06:15 PM
CompWedgeEngines
Syracuse,NY
I obviously cant answer that. I deal directly with the owner and I can guarantee you I can get whatever answer you need.
I am sure Kevin or Dave can as well.
How can I help?
RIP Monte Smith
[Re: gch]
#188241
01/09/09 11:40 PM
01/09/09 11:40 PM
Posts: 853 Brisbane Australia
572B1
Brisbane Australia
I have had good service from the rollmaster billet chain I purchased from Hensley years ago.Still in service to this day.I believe they are(were)made in Australia.
They still are made over here,Rollmaster race proven for over twenty years. Best in the business.
[Re: 451Mopar]
#188244
01/10/09 12:57 AM
01/10/09 12:57 AM
572B1
Brisbane Australia
I have the 440 source billit with torrington thrust washer and the optional rolon chain and it fits really well. No miles on it so far. Not sure where the source gets these from, but the billit Cloyes is not much more expensive?
The 360 LA emgine has the standard Cloyes timming set, but I added the magnum chain tensioner to pick up any slack.
Rolon is a poor quality chain. Rollmaster premium sets come with Iwis chain from Germany.The cheaper timing sets for std motors come with rolon chains. Rollmaster tested numerous chains and found Iwis in germany to make the best quality chains.I guess he got it right as Crane cams in the usa market rollmaster as there own brand.
[Re: 451Mopar]
#188245
01/10/09 12:59 AM
01/10/09 12:59 AM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Cloyes in both C's here. With over two tons o fun,and a heavy foot,it is my preference.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
