kick-down linkage problem #187980
01/08/09 05:01 PM
01/08/09 05:01 PM
Anonymous OP
Anonymous OP
i have a 69 rr with a 440 auto. if i adjust the linkage according to motor's manual it will overcenter on the bell crank. are there different lenths shafts from the bellcrank to the trans? i see lokar sells a kickdown cable. could this solve the problem? it has an avs carb. thank you
Re: kick-down linkage problem #187981
01/08/09 05:49 PM
01/08/09 05:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If your not looking for origonality, the cable set-up is pretty nice. It's easy to install and you don't have to hunt for the correct linkage with all look the same to me. I have the cable set-up on a big block Dakota.
Re: kick-down linkage problem [Re: burdar] #187982
01/09/09 12:35 PM
01/09/09 12:35 PM
Anonymous OP
Anonymous OP
thank you for the info
Re: kick-down linkage problem #187983
01/09/09 12:50 PM
01/09/09 12:50 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
If you decide to go with the cable set up, I have used both the Lokar and the one from Bouchillion Performance. The Lokar never really did work right for me, but the one from Bouchillion works perfectly.Hope this helps.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: kick-down linkage problem [Re: 440abody] #187984
01/12/09 12:24 PM
01/12/09 12:24 PM
Anonymous OP
Anonymous OP
i think i may have it fixed. thanks to all for the help
Re: kick-down linkage problem #187985
01/12/09 08:04 PM
01/12/09 08:04 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
To answer your question...Yes there are different length linkages and you need the specific linkage for the application...B or RB,2 or 4 bbl, etc...
Re: kick-down linkage problem [Re: screamindriver] #187986
01/21/09 10:40 AM
01/21/09 10:40 AM
Anonymous OP
Anonymous OP
thanks for the added info . that will help in my search for the right stuff.
Re: kick-down linkage problem #187987
01/21/09 10:51 AM
01/21/09 10:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it is available as a reproduction
