i have a 69 rr with a 440 auto. if i adjust the linkage according to motor's manual it will overcenter on the bell crank. are there different lenths shafts from the bellcrank to the trans? i see lokar sells a kickdown cable. could this solve the problem? it has an avs carb. thank you
