projector head lights #1877863
07/25/15 02:24 PM
07/25/15 02:24 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
i have a 2004 dodge 3500 that the head lights are getting pretty fogged over from the road environment and weather. I know there are polishing kits to bring the clearness back but was wondering about the new look of the projector lights. Do they light up the road better than the stock lights?
Re: projector head lights [Re: rowin4] #1877873
07/25/15 02:43 PM
07/25/15 02:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Biggest problem with the projector lights is that there is five adjustments to get them pointed right and the adjusters are on the back side. That means you have to keep R&Ring them to get the adjustment right. I just went through this and ended up sending them back and going with stock style replacements. Oh and the projectors come with those ricer LEDs.
Re: projector head lights [Re: rowin4] #1877953
07/25/15 05:59 PM
07/25/15 05:59 PM
places
79powerwagon Offline
places
Just wet sand you current headlights, then clear coat them with a UV stable clear for plastic. I did that to my Dakota, it took almost 20 minutes total, and the difference is remarkable! Also only cost $7.00.
I HATE factory projector headlights, I can't see the aftermarket ones being even 1/10 as useful (since they're designed for sales, not usefulness).
Re: projector head lights [Re: rowin4] #1877981
07/25/15 06:52 PM
07/25/15 06:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
On the 2004 truck you can use tooth paste a a buffer to clean them up or pretty cheap you can replace them with EBay units. Sanding the newer type will mess them up worse than the clouding. I used a pair of these. Takes about 10 minutes a side to swap. He excepted a $46 ea offer.
http://www.ebay.com/itm/131487605635?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: projector head lights [Re: 79powerwagon] #1878084
07/25/15 10:27 PM
07/25/15 10:27 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
<snip>
What grit did you use?
Re: projector head lights [Re: rowin4] #1878279
07/26/15 08:35 AM
07/26/15 08:35 AM
places
places
I just used 400 because that is all the store had. Really, you should try to go to 1000 (or close), but for me, this was fine. The clear is a Rustoleum product. I posted about it a few weeks ago, I think in the General section.
Re: projector head lights [Re: rowin4] #1878285
07/26/15 08:39 AM
07/26/15 08:39 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Thanks!dakota
Re: projector head lights [Re: rowin4] #1878406
07/26/15 01:54 PM
07/26/15 01:54 PM
places
places
Re: projector head lights [Re: rowin4] #1878446
07/26/15 02:53 PM
07/26/15 02:53 PM
rowin4 Offline OP
rowin4  Offline OP
Thanks Stumpy for the projector light info. I guess thats not what I want after all. When I tow a trailer the lights would be shinning in the trees if adjusted for normal ride. So I guess it's try the sand and buff. Thanks 79 powerwagon for the clear coat tip.
