projector head lights
#1877863
07/25/15 02:24 PM
07/25/15 02:24 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
i have a 2004 dodge 3500 that the head lights are getting pretty fogged over from the road environment and weather. I know there are polishing kits to bring the clearness back but was wondering about the new look of the projector lights. Do they light up the road better than the stock lights?
Re: projector head lights
[Re: 79powerwagon]
#1878084
07/25/15 10:27 PM
07/25/15 10:27 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
Just wet sand you current headlights, then clear coat them with a UV stable clear for plastic. I did that to my Dakota, it took almost 20 minutes total, and the difference is remarkable! Also only cost $7.00.
<snip> What grit did you use?
[Re: rowin4]
#1878446
07/26/15 02:53 PM
07/26/15 02:53 PM
rowin4
Thanks Stumpy for the projector light info. I guess thats not what I want after all. When I tow a trailer the lights would be shinning in the trees if adjusted for normal ride. So I guess it's try the sand and buff. Thanks 79 powerwagon for the clear coat tip.
