TTTI hemi ebody header fitment issues-pics inside #1878124
07/25/15 11:35 PM
07/25/15 11:35 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Anybody install 2 1/8 tti hemi headers on an ebody and have the driver's side header hit the transmission pan lip? Also interferes bigtime with the shifting linkage. Clears everywhere else though.
Ps. Dont mind the dingy old pan, just on for installing purposes lol.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878130
07/25/15 11:40 PM
07/25/15 11:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
The TTI site says it will interfere with the shift linkage, you did see that when you ordered them right ?
As for hittin the pan, maybe show tti a pic and see what they say on that? Or just dent it over perhaps.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: OzHemi] #1878156
07/26/15 12:07 AM
07/26/15 12:07 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
No I didnt read it before they were bought, its not my car. But to do the mod they say to do in the instructions to the linkage support ( shorten 1/4") isnt going to be enough. Did you look at the picture? Its off by a bunch. smile
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878302
07/26/15 10:11 AM
07/26/15 10:11 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
Bump.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878311
07/26/15 10:41 AM
07/26/15 10:41 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
When the headers are made with stock measurements a small amount of machining (decked block) may throw them off. Try doubling the flange gasket. A small amount spacing at one end of the header may result in 1/4" or more at the other end.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878336
07/26/15 11:41 AM
07/26/15 11:41 AM
U
Uncle Barry Offline
Uncle Barry  Offline
U
It just seems like the collector end is bent into the transmission on the drivers side. Other than that, everything else has room.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878353
07/26/15 12:21 PM
07/26/15 12:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are you using?:
Schumacher conversion mounts?
Original Hemi K-member? What car did it come out of? What number is stamped on the coin?
Repro K-member? If so who's?
What company's repro hemi motor mounts are you using?
What type/kind of trans mount are you using?
What heads are you using?
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878360
07/26/15 12:42 PM
07/26/15 12:42 PM
U
Uncle Barry Offline
Uncle Barry  Offline
U
Schumacher mounts. Factory k member. Stock trans mount. MP heads.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Uncle Barry] #1878397
07/26/15 01:42 PM
07/26/15 01:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
On this deal though the mounts don't enter into the equation. That header would hit if the trans, engine and headers were out of the car.
Sheldon
Sheldon
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1878409
07/26/15 02:01 PM
07/26/15 02:01 PM
U
Uncle Barry Offline
Uncle Barry  Offline
U
That's my thoughts too Sheldon
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1885747
08/05/15 05:31 PM
08/05/15 05:31 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I have Schumacher mounts on a V8 K-frame. My TTi 2.125 headers do not hit the pan.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1885754
08/05/15 05:42 PM
08/05/15 05:42 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I would bet that that driversideheader was not sitting correctly in the jigg during welding. No other way for them to hit the tranmission pan unless your transmission is bent and that is not a likely option.
Mounts are irrelevant in this case.
Re: TTTI hemi ebody header fitment issues-pics inside [Re: Hot 340] #1885815
08/05/15 07:40 PM
08/05/15 07:40 PM
BDW Offline
BDW  Offline
Double check PN, I had similar issue with TTI install hitting linkage.
They had sent wrong part.
I only have a 340, but they may have made a mistake with you too......
