Re: Exhaust Cutouts
[Re: JFChallenger440]
#1877874
07/25/15 02:45 PM
07/25/15 02:45 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
They should fit I have them on my 65.Just adjust the cut outs so they aim away from the floor.The diamater is the same as a pipe.Rocky
Chrysler Firepower
Re: Exhaust Cutouts
#1878709
07/26/15 10:29 PM
07/26/15 10:29 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I like to use the Walker band clamps, they don't crimp your pipes like the regular muffler clamps do. Then I put a small screw through the clamp and pipe to prevent anything from slipping apart even though the Walker clamps hold tight. The Summit Racing band clamps are complete junk and don't clamp tight.
If you run a quiet, restrictive exhaust system the cutouts are going to make the car a couple tenths quicker. If you run a 3" system with an x-pipe and good mufflers, the cutouts may not do much.
On a side note, I installed DMH electic 3" cutouts on my big block Duster and it is by far the coolest thing I've ever installed on a car, they are a blast.
