Need a little carb help. UPDATE
#1877796
07/25/15 12:28 PM
07/25/15 12:28 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Have a guy coming to look at the race car tomorrow. So I thought it would be a good idea to start it up. Has been started since late April. Well fuel pressure came up ok. cranked it over and it hit once and that was it. Crank no start. So I pulled a plug. Fuel soaked checked for fire. Got fire. Turned the FP back on and I have fuel running out the transition slots on the primary side. Is this a needle and seat problem or should I be looking for something else. In the past I have had a problem with the o-rings on the needle and seat. But in those instances it would push fuel out the vent tubes. Thanks in advance for your input. Jim
Re: Need a little carb help.
[Re: rt66jim]
#1877824
07/25/15 01:12 PM
07/25/15 01:12 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Quick little possible fix.... Just try a couple of good firm raps on the top of the bowls with an end wrench. Often times the floats/ seats get hung up from fuel sitting in them. 10 second check and good chance you will get lucky.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: rt66jim]
#1878370
07/26/15 01:00 PM
07/26/15 01:00 PM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
Rubber metering block gaskets, when not sealing properly often had raw fuel running out the transition slots with no other signs of N&S problems. Only worked well on machined main body surfaces.
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
[Re: rt66jim]
#1878424
07/26/15 02:21 PM
07/26/15 02:21 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Stand in line brother cos I`ve done things I would never even post............. Should run better now.
