Need a little carb help. UPDATE #1877796
07/25/15 12:28 PM
07/25/15 12:28 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Have a guy coming to look at the race car tomorrow. So I thought it would be a good idea to start it up. Has been started since late April. Well fuel pressure came up ok. cranked it over and it hit once and that was it. Crank no start. So I pulled a plug. Fuel soaked checked for fire. Got fire. Turned the FP back on and I have fuel running out the transition slots on the primary side. Is this a needle and seat problem or should I be looking for something else. In the past I have had a problem with the o-rings on the needle and seat. But in those instances it would push fuel out the vent tubes. Thanks in advance for your input. Jim
Re: Need a little carb help. [Re: rt66jim] #1877810
07/25/15 12:51 PM
07/25/15 12:51 PM
AndyF Offline
AndyF  Offline
Most likely a flooding problem. Might be a bad float or a stuck needle. Should be able to fix it in a few minutes by pulling the bowls. Holley type carb I assume?
Re: Need a little carb help. [Re: rt66jim] #1877824
07/25/15 01:12 PM
07/25/15 01:12 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Quick little possible fix.... Just try a couple of good firm raps on the top of the bowls with an end wrench. Often times the floats/ seats get hung up from fuel sitting in them.
10 second check and good chance you will get lucky.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Need a little carb help. [Re: rt66jim] #1877826
07/25/15 01:15 PM
07/25/15 01:15 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Andy that is what I suspected, NS. Don I tried that one too. I think the fuel has worked on the NS o-ring.
Re: Need a little carb help. [Re: rt66jim] #1878370
07/26/15 01:00 PM
07/26/15 01:00 PM
Albert Lea, MN
GTX5877 Online work
GTX5877  Online Work
Albert Lea, MN
Rubber metering block gaskets, when not sealing properly often had raw fuel running out the transition slots with no other signs of N&S problems. Only worked well on machined main body surfaces.
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: Need a little carb help. [Re: rt66jim] #1878384
07/26/15 01:19 PM
07/26/15 01:19 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have had issues with some fuels gumming the needle and seat if the engine hasn't been run on a regular basis.
Re: Need a little carb help. [Re: rt66jim] #1878419
07/26/15 02:14 PM
07/26/15 02:14 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well I am going to post what I found so others might learn. 1. It's terrible getting old sometimes. 2. The dog at my homework. 3. I guess I forget things now. 4. There was no gasket between the metering block and the main body. 5. And I had it off twice before I figured it out. At least I am still able to figure it out. It's running all is well and life is good. Where is that smiley face. Jim
Re: Need a little carb help. [Re: rt66jim] #1878424
07/26/15 02:21 PM
07/26/15 02:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stand in line brother cos I`ve done things I would never even post............. laugh2 Should run better now.
Re: Need a little carb help. [Re: rt66jim] #1878458
07/26/15 03:05 PM
07/26/15 03:05 PM
AndyF Offline
AndyF  Offline
Interesting that you had fuel coming out the transition slots and not everywhere else. Must of sealed up well enough to keep fuel from dripping all the time.
