Re: Cooling again...Electric water pump GPM for street
[Re: Thumperdart]
#1858881
06/28/15 02:13 PM
06/28/15 02:13 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
That`s it man and sure wish I knew about this yeaars ago............. me too.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#1858939
06/28/15 03:50 PM
06/28/15 03:50 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
That`s it man and sure wish I knew about this yeaars ago............. me too. Went for a cruise and although it`s only 99* it never went above 180 so I`ll head out later when it`s 108................
[Re: Thumperdart]
#1859026
06/28/15 06:04 PM
06/28/15 06:04 PM
Posts: 1,845 Tampa
DusterDave
Tampa
That`s it man and sure wish I knew about this yeaars ago............. me too. Went for a cruise and although it`s only 99* it never went above 180 so I`ll head out later when it`s 108................ How the heck can you drive in that kind of heat with no A/C in the car? I'm assuming you Dart doesn't have A/C.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1859043
06/28/15 06:35 PM
06/28/15 06:35 PM
Thumperdart
State of confusion
Who needs ac in a 9-second car........ Plus it would slow me down. Some day I will have a fast street car WITH air but for now I tolerate this thing and love every minute of it actually............
[Re: DusterDave]
#1859467
06/29/15 03:26 AM
06/29/15 03:26 AM
mopar65
That`s it man and sure wish I knew about this yeaars ago............. me too. Went for a cruise and although it`s only 99* it never went above 180 so I`ll head out later when it`s 108................ How the heck can you drive in that kind of heat with no A/C in the car? I'm assuming you Dart doesn't have A/C. but its a dry heat.lol
support our troops
[Re: RV2]
#1861980
07/02/15 01:36 PM
07/02/15 01:36 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Thanks for the pic. Great info
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: mopar65]
#1862070
07/02/15 03:07 PM
07/02/15 03:07 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I ran the 45 gph Meziere for ever. One thing I did that helped is I tapped the hole in the housing under the thermostat. put a plug in it and drilled a 1/8th inch hole in the plug. that was good for about 10* And did the water just pour out or what? I think you stopped short in your explanation. The 45 gpm pump he's referring to is the drop-in pump that fits the stock housing (same one I have). There is a bypass hole underneath the thermostat in a stock housing. You tap it for 3/8" npt (no need to drill), put a pipe plug in it, then drill a 1/8" hole through the plug. This is def. worth doing...dropped mine about 10° also. It reduces the amount of hot water that's recirculated through the motor. could you post a part number for the one you have? The pump I have is a Meziere WP105SHD...it's the black version that flows 45 gpm and drops into the factory housing.
[Re: Thumperdart]
#1871291
07/16/15 12:42 AM
07/16/15 12:42 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I, as well, think that I have solved my cooling issue. I upgraded the pump from a 35GPM to a 55GPM. Now when it gets hot I flip the switch on, and it is able to cool the car and bring it under control. I haven't had a super hot day to try it, but am looking forward to it!! Thanks for all the suggestions
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: 74-440Charger]
#1873339
07/19/15 04:54 AM
07/19/15 04:54 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What is that passage for? What would happen if closed off completely? You could get air pockets in the head, its a bypass for when thermostat is closed
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1874163
07/20/15 10:47 AM
07/20/15 10:47 AM
an8sec70cuda
What is that passage for? What would happen if closed off completely? You could get air pockets in the head, its a bypass for when thermostat is closed Need to have a small hole at least to vent the air.
