Page 3 of 3 1 2 3
Re: Cooling again...Electric water pump GPM for street [Re: KDY] #1858669
06/28/15 02:16 AM
06/28/15 02:16 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Like this?
Re: Cooling again...Electric water pump GPM for street [Re: RV2] #1858798
06/28/15 12:13 PM
06/28/15 12:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s it man and sure wish I knew about this yeaars ago............. laugh2
Re: Cooling again...Electric water pump GPM for street [Re: Thumperdart] #1858881
06/28/15 02:13 PM
06/28/15 02:13 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
me too.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Cooling again...Electric water pump GPM for street [Re: mopar65] #1858939
06/28/15 03:50 PM
06/28/15 03:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
me too.
Went for a cruise and although it`s only 99* it never went above 180 so I`ll head out later when it`s 108................
Re: Cooling again...Electric water pump GPM for street [Re: Thumperdart] #1859026
06/28/15 06:04 PM
06/28/15 06:04 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
me too.
How the heck can you drive in that kind of heat with no A/C in the car? I'm assuming you Dart doesn't have A/C.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Cooling again...Electric water pump GPM for street [Re: DusterDave] #1859043
06/28/15 06:35 PM
06/28/15 06:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Who needs ac in a 9-second car........ biggrin Plus it would slow me down. Some day I will have a fast street car WITH air but for now I tolerate this thing and love every minute of it actually............ realcrazy
Re: Cooling again...Electric water pump GPM for street [Re: DusterDave] #1859467
06/29/15 03:26 AM
06/29/15 03:26 AM
mopar65 Offline
mopar65  Offline
me too.
but its a dry heat.lol
Re: Cooling again...Electric water pump GPM for street [Re: mopar65] #1859553
06/29/15 11:50 AM
06/29/15 11:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Actually it`s way more humid in Vegas than in Cally where I`m heading to this evening and never did take another drive cos the beer was flowin and I don`t drink n drive................ thumbs
Re: Cooling again...Electric water pump GPM for street [Re: dart440_72] #1859600
06/29/15 01:19 PM
06/29/15 01:19 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Wish this thread came up BEFORE I put my new pump and housing on last week.
Oh well..... guess I'll get myself a 3/8" pipe plug, drain the system and get tapping laugh2
New radiator, pump, housing and fan
Re: Cooling again...Electric water pump GPM for street [Re: RV2] #1861980
07/02/15 01:36 PM
07/02/15 01:36 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Originally Posted By RV2
Like this?
Thanks for the pic. Great info
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Cooling again...Electric water pump GPM for street [Re: mopar65] #1862070
07/02/15 03:07 PM
07/02/15 03:07 PM
an8sec70cuda Offline
Originally Posted By a9sec70cuda
Originally Posted By rowin4
Originally Posted By sixpackgut
I ran the 45 gph Meziere for ever. One thing I did that helped is I tapped the hole in the housing under the thermostat. put a plug in it and drilled a 1/8th inch hole in the plug. that was good for about 10*
And did the water just pour out or what? I think you stopped short in your explanation.
The 45 gpm pump he's referring to is the drop-in pump that fits the stock housing (same one I have). There is a bypass hole underneath the thermostat in a stock housing. You tap it for 3/8" npt (no need to drill), put a pipe plug in it, then drill a 1/8" hole through the plug. This is def. worth doing...dropped mine about 10° also. It reduces the amount of hot water that's recirculated through the motor.
could you post a part number for the one you have?
The pump I have is a Meziere WP105SHD...it's the black version that flows 45 gpm and drops into the factory housing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cooling again...Electric water pump GPM for street [Re: an8sec70cuda] #1870873
07/15/15 01:13 PM
07/15/15 01:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Well, I went to a car hang out yesterday about 10 miles away and the temp never went over 195 and averaged 185-190 cruising but it was closer to 100 degrees out and not the 112 prior. It`s definitely better so thankxx again for the tip guys............... beer
Re: Cooling again...Electric water pump GPM for street [Re: Thumperdart] #1871291
07/16/15 12:42 AM
07/16/15 12:42 AM
Medina, OH
dart440_72 Offline OP
Medina, OH
I, as well, think that I have solved my cooling issue. I upgraded the pump from a 35GPM to a 55GPM. Now when it gets hot I flip the switch on, and it is able to cool the car and bring it under control. I haven't had a super hot day to try it, but am looking forward to it!! Thanks for all the suggestions
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Cooling again...Electric water pump GPM for street [Re: sixpackgut] #1873262
07/19/15 12:15 AM
07/19/15 12:15 AM
FL
74-440Charger Offline
FL
What is that passage for? What would happen if closed off completely?
Re: Cooling again...Electric water pump GPM for street [Re: 74-440Charger] #1873339
07/19/15 04:54 AM
07/19/15 04:54 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
You could get air pockets in the head, its a bypass for when thermostat is closed
Re: Cooling again...Electric water pump GPM for street [Re: dart440_72] #1873407
07/19/15 11:28 AM
07/19/15 11:28 AM
FL
FL
Thanks, I may try this one.
Re: Cooling again...Electric water pump GPM for street [Re: sixpackgut] #1874163
07/20/15 10:47 AM
07/20/15 10:47 AM
iagree Need to have a small hole at least to vent the air.
CHIP
Re: Cooling again...Electric water pump GPM for street [Re: dart440_72] #1875698
07/22/15 12:25 PM
07/22/15 12:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
just checked and it's a 1/4" pipe plug for easy tapping.
Page 3 of 3 1 2 3
