No Leak Thermostat Housing #1860446
06/30/15 12:51 PM
06/30/15 12:51 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
I know it has been talked about before . . . just thought I would give a shout out to "Terry's Auto "Lab" for his no leak t-stat housing !!!
For myself, no matter a big block or small block, I have always had some sort of seepage or leakage from the factory t-stat housing . . . his unit takes all the guess work and silicone sealant, etc out of the installation ! Sure it is a bit pricey, but not having a streak from the t-stat housing on a nice clean painted engine, is way worth it !!
One note, insure you have a "smaller diameter" 80's up thermostat !! For me, it certainly is worth the expense !!!
http://www.terrysautolab.com/
Mark
Re: No Leak Thermostat Housing [Re: a12rag] #1860481
06/30/15 01:32 PM
06/30/15 01:32 PM
for a no leak housing my vote is the NAPA cast iron unit. not chrome obviously but just a FYI
Re: No Leak Thermostat Housing [Re: a12rag] #1860559
06/30/15 03:16 PM
06/30/15 03:16 PM
a12rag Offline OP
a12rag  Offline OP
You still need to futz around with a gasket . . . O ring seals with the unit from Terry's . . .no gasket required !! I have a cast iron unit on my 74 Duster360, and it has ever so slight seepage happen over all these years . . . no matter how clean I get surfaces and level and slight bit of silicone. I like O rings . . .
Re: No Leak Thermostat Housing [Re: a12rag] #1860636
06/30/15 05:22 PM
06/30/15 05:22 PM
P
Paul_Fancsali Offline
P
Use cast iron and let silicone set up for at least 6 hours and do not do work on humid or day cooler then 60*
Re: No Leak Thermostat Housing [Re: a12rag] #1860676
06/30/15 05:49 PM
06/30/15 05:49 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's a nice waterneck but kinda pricey, I tried 3 different ones with leaks, finally bought the $34 billet aluminum one from Mancini, no gasket, just some gray RTV, no leaks!
http://www.manciniracing.com/mabialwane.html
If you buy from Napa make sure it has a lip on it to keep the hose on, mine didn't so I took it back.
Re: No Leak Thermostat Housing [Re: RapidRobert] #1860895
06/30/15 10:33 PM
06/30/15 10:33 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Napa worked great for me too..
Re: No Leak Thermostat Housing [Re: AARCONV] #1860936
06/30/15 11:18 PM
06/30/15 11:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
X3 twocents
Re: No Leak Thermostat Housing [Re: a12rag] #1860938
06/30/15 11:22 PM
06/30/15 11:22 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
You guys with the Napa waternecks, did it have the lip at the top to help hold the hose on? My new one did not a couple months ago, no way I'd run it like that.
Re: No Leak Thermostat Housing [Re: a12rag] #1865961
07/07/15 05:20 PM
07/07/15 05:20 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I've got a NAPA aluminum neck, works great. The flange is much thicker than stock, has the hose barb.
Re: No Leak Thermostat Housing [Re: a12rag] #1865986
07/07/15 05:59 PM
07/07/15 05:59 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Mark
I put one of these on my Barracuda and it worked great. The iron ones are ok, but this one is the best!
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: No Leak Thermostat Housing [Re: dynorad] #1866152
07/07/15 09:58 PM
07/07/15 09:58 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Don't mate iron and aluminum together. My steel o-ring housing warped and corroded on my aluminum pump after 5 yrs.
The little old lady from Pasadena is back!
Re: No Leak Thermostat Housing [Re: Barnstorm] #1866742
07/08/15 05:20 PM
07/08/15 05:20 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
I have a Terry's Auto Lab T/stat housing on my Duster, have had it on there for almost 3 years now...not a single problem with it!
Plymouth Makes It!
Re: No Leak Thermostat Housing [Re: RoadRunnerLuva] #1868134
07/11/15 08:33 AM
07/11/15 08:33 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I tried ordering the NAPA cast housing version. They ordered it twice, both came in two different versions than the pictured one on the website, (which is the one I wanted)! Neither one would work so ordered this aluminum one off e-bag from Crankshaft Depot. No leaks, got it on one day!
Look under 440 thermostat housing
Re: No Leak Thermostat Housing [Re: 63stabamatic] #1868182
07/11/15 12:26 PM
07/11/15 12:26 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I had this problem also. I always used the Napa housings, but when I ordered one a week ago it appears they have changed venders. The one I got has a boss on it for nipple and didn't have a thick flange. To bad as they were cheap and nicely made.
The only Carbs I care about are under the hood!
Re: No Leak Thermostat Housing [Re: a12rag] #1868191
07/11/15 12:42 PM
07/11/15 12:42 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Nice piece
It's 1/4 the price I paid for my car.
Re: No Leak Thermostat Housing [Re: NTOLERANCE] #1868204
07/11/15 01:26 PM
07/11/15 01:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here is my no leak,not a drop in 23 yrs ! shruggy
Re: No Leak Thermostat Housing [Re: a12rag] #1868570
07/12/15 01:19 AM
07/12/15 01:19 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Got real tired of housing leaks and trying different sealants. I've had three different race cars with the Billet Specialties housings. They use O-rings and have a nice thick base. No sealant, no leaks and no cleanup when removed. Yes they're a little pricey but no more aggravation is worth something to me.
Re: No Leak Thermostat Housing [Re: a12rag] #1870100
07/14/15 02:25 PM
07/14/15 02:25 PM
a12rag Offline OP
a12rag  Offline OP
Great to see that people are figuring out what works for them !!! For myself, on a car I try to drive 5-8k miles per year, Terry's was the choice for me !
Re: No Leak Thermostat Housing [Re: a12rag] #1870119
07/14/15 02:54 PM
07/14/15 02:54 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Shame someone can't make one that looks stock
