No Leak Thermostat Housing
#1860446
06/30/15 12:51 PM
06/30/15 12:51 PM
Posts: 2,922 Calgary, Alberta Canada
a12rag
I know it has been talked about before . . . just thought I would give a shout out to "Terry's Auto "Lab" for his no leak t-stat housing !!! For myself, no matter a big block or small block, I have always had some sort of seepage or leakage from the factory t-stat housing . . . his unit takes all the guess work and silicone sealant, etc out of the installation ! Sure it is a bit pricey, but not having a streak from the t-stat housing on a nice clean painted engine, is way worth it !! One note, insure you have a "smaller diameter" 80's up thermostat !! For me, it certainly is worth the expense !!! http://www.terrysautolab.com/Mark
Re: No Leak Thermostat Housing
[Re: a12rag]
#1860481
06/30/15 01:32 PM
06/30/15 01:32 PM
RapidRobert
for a no leak housing my vote is the NAPA cast iron unit. not chrome obviously but just a FYI
[Re: a12rag]
#1860676
06/30/15 05:49 PM
06/30/15 05:49 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
That's a nice waterneck but kinda pricey, I tried 3 different ones with leaks, finally bought the $34 billet aluminum one from Mancini, no gasket, just some gray RTV, no leaks! http://www.manciniracing.com/mabialwane.htmlIf you buy from Napa make sure it has a lip on it to keep the hose on, mine didn't so I took it back.
[Re: RapidRobert]
#1860895
06/30/15 10:33 PM
06/30/15 10:33 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
for a no leak housing my vote is the NAPA cast iron unit. not chrome obviously but just a FYI Napa worked great for me too..
[Re: AARCONV]
#1860936
06/30/15 11:18 PM
06/30/15 11:18 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
for a no leak housing my vote is the NAPA cast iron unit. not chrome obviously but just a FYI Napa worked great for me too.. X3
[Re: a12rag]
#1860938
06/30/15 11:22 PM
06/30/15 11:22 PM
ProSport
Akron, Ohio
You guys with the Napa waternecks, did it have the lip at the top to help hold the hose on? My new one did not a couple months ago, no way I'd run it like that.
[Re: a12rag]
#1865986
07/07/15 05:59 PM
07/07/15 05:59 PM
Posts: 701 Northern California
lilcuda
Northern California
I know it has been talked about before . . . just thought I would give a shout out to "Terry's Auto "Lab" for his no leak t-stat housing !!! For myself, no matter a big block or small block, I have always had some sort of seepage or leakage from the factory t-stat housing . . . his unit takes all the guess work and silicone sealant, etc out of the installation ! Sure it is a bit pricey, but not having a streak from the t-stat housing on a nice clean painted engine, is way worth it !! One note, insure you have a "smaller diameter" 80's up thermostat !! For me, it certainly is worth the expense !!! http://www.terrysautolab.com/Mark I put one of these on my Barracuda and it worked great. The iron ones are ok, but this one is the best!
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: dynorad]
#1866152
07/07/15 09:58 PM
07/07/15 09:58 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Don't mate iron and aluminum together. My steel o-ring housing warped and corroded on my aluminum pump after 5 yrs.
The little old lady from Pasadena is back!
[Re: Barnstorm]
#1866742
07/08/15 05:20 PM
07/08/15 05:20 PM
Posts: 5,349 Planet Earth
RoadRunnerLuva
Planet Earth
I have a Terry's Auto Lab T/stat housing on my Duster, have had it on there for almost 3 years now...not a single problem with it!
Plymouth Makes It!
[Re: RoadRunnerLuva]
#1868134
07/11/15 08:33 AM
07/11/15 08:33 AM
Posts: 277 Palmyra, NY
63stabamatic
Palmyra, NY
I tried ordering the NAPA cast housing version. They ordered it twice, both came in two different versions than the pictured one on the website, (which is the one I wanted)! Neither one would work so ordered this aluminum one off e-bag from Crankshaft Depot. No leaks, got it on one day!
Look under 440 thermostat housing
[Re: 63stabamatic]
#1868182
07/11/15 12:26 PM
07/11/15 12:26 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I had this problem also. I always used the Napa housings, but when I ordered one a week ago it appears they have changed venders. The one I got has a boss on it for nipple and didn't have a thick flange. To bad as they were cheap and nicely made.
The only Carbs I care about are under the hood!
[Re: a12rag]
#1868191
07/11/15 12:42 PM
07/11/15 12:42 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Nice piece
It's 1/4 the price I paid for my car.
