Replacing mechanical fuel pump. 87 Chrysler 318 ? #1869185
07/13/15 02:16 AM
07/13/15 02:16 AM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
OK< I replaced it 6 years ago. It is no longer pumping.
I just removed it, took the alternator off first.
My question's about the fuel pump push rod.
Does the 318 have one?
I did not see one fall out, and did not feel anything in the hole to indicate one is in there.
Can I just lube the end of the arm and shove the new one in, or should I extract the push rod if one is in there.
Motor has only 52,000 miles so I dont think the push rod is bad.
Is there a push rod in the 318? Is it OK to just leave it in place if it is not falling out?
I have a Mopar shop manual but it does not show. It does say the pump works off of a cam lobe or something.
YORKER.
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: Replacing mechanical fuel pump. 87 Chrysler 318 ? [Re: yorker] #1869188
07/13/15 02:22 AM
07/13/15 02:22 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The fuel pump lever runs on an offset hub on the cam sprocket and is lubricated by oil splash off the timing chain & gears. There is not a push rod. Gene
Re: Replacing mechanical fuel pump. 87 Chrysler 318 ? [Re: yorker] #1869189
07/13/15 02:25 AM
07/13/15 02:25 AM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
Gene, thanks for the reply. I will try and delete the post.
Glad I dont have a little rod to mess with.
Re: Replacing mechanical fuel pump. 87 Chrysler 318 ? [Re: yorker] #1869209
07/13/15 03:14 AM
07/13/15 03:14 AM
as you insert the lever into the tcover opening angle it down then come up as the lever rides under the eccentric & IF it wants to compress alot during this installation pull it back out & turn the crank with a 1&1/4" socket/short extension/breaker bar to get on the base circle of the eccentric. hit the sweet spot where there is just a little bit of compression
Re: Replacing mechanical fuel pump. 87 Chrysler 318 ? [Re: yorker] #1869244
07/13/15 08:39 AM
07/13/15 08:39 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I had the fuel pump eccentric wear out on a 318 I had, it was either take the timing cover off and fix it or go electric for the pump. you might be able to see it with the pump out with a mirror or bore scope.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Replacing mechanical fuel pump. 87 Chrysler 318 ? [Re: yorker] #1869382
07/13/15 01:27 PM
07/13/15 01:27 PM
moparx Offline
moparx  Offline
DO NOT DELETE YOUR POST ! tsk some on this board take offense at this tactic. also, this info helps others at times. i'm not trying to give you a hard time, so please do not take offense at my comment.
beer
