Re: Replacing mechanical fuel pump. 87 Chrysler 318 ?
[Re: yorker]
#1869209
07/13/15 03:14 AM
07/13/15 03:14 AM
RapidRobert
as you insert the lever into the tcover opening angle it down then come up as the lever rides under the eccentric & IF it wants to compress alot during this installation pull it back out & turn the crank with a 1&1/4" socket/short extension/breaker bar to get on the base circle of the eccentric. hit the sweet spot where there is just a little bit of compression
[Re: yorker]
#1869244
07/13/15 08:39 AM
07/13/15 08:39 AM
Posts: 631 Casco, MI
Savoy1964
Casco, MI
I had the fuel pump eccentric wear out on a 318 I had, it was either take the timing cover off and fix it or go electric for the pump. you might be able to see it with the pump out with a mirror or bore scope.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
