04 2500 AC #1868840
07/12/15 03:58 PM
07/12/15 03:58 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
I need to charge the AC on my 04 ram ctd .I bought a new can of ref.and borrowed my buddies hose and gauge.it works on his truck but the low side of mine is way too big to fit the hose.does the ctd take a diff hook up or is there an adapter?
Re: 04 2500 AC [Re: bonefish] #1868923
07/12/15 06:48 PM
07/12/15 06:48 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
You are probably not looking at the low side port (the high side is the one out front where it is nice and convenient). The low side is way back up under the cowl near the firewall on the receiver dryer. It is a PIA to get the hose seated. Use caution....
This space not for rent.
Re: 04 2500 AC [Re: Bill_T] #1869027
07/12/15 10:04 PM
07/12/15 10:04 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
This.
And it's even worse when it's a 4x4. cry
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 04 2500 AC [Re: I_bleed_MOPAR] #1869061
07/12/15 10:55 PM
07/12/15 10:55 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its the one way in the back and it has a grey cap on it marked with a L.so far ive measured 4 other cars including a Dakota and a f-150,they are all the same and the nozzle fits them all.
Re: 04 2500 AC [Re: bonefish] #1869287
07/13/15 10:53 AM
07/13/15 10:53 AM
Buford, GA
Buford, GA
Strange. work I checked mine when the clutch went out. It was a royal pain to get it on the fitting with my big paws. blush
Tim
'71 Charger 383/727
Re: 04 2500 AC [Re: I_bleed_MOPAR] #1869342
07/13/15 12:10 PM
07/13/15 12:10 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
some pics
Re: 04 2500 AC [Re: bonefish] #1869356
07/13/15 12:41 PM
07/13/15 12:41 PM
Buford, GA
Buford, GA
Mine is different (being an '06, I guess) as the port is on top of the receiver-drier. I wish mine was out in the open like that. wink
Do you have a full set of gauges or just the recharge kit? If it's just the kit hose someone may have changed it to a high-side connector. work
Tim
'71 Charger 383/727
Re: 04 2500 AC [Re: I_bleed_MOPAR] #1869378
07/13/15 01:21 PM
07/13/15 01:21 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its an unmodified recharge kit,it works on other Low side ports shruggy
Re: 04 2500 AC [Re: bonefish] #1869397
07/13/15 02:18 PM
07/13/15 02:18 PM
Buford, GA
Buford, GA
It has me stumped. Found some pictures online and the line, port, and cap look just like yours. shruggy
Wish you were closer, I'd be glad to take a look at it.
Tim
'71 Charger 383/727
