Clutch for b body with 440
#1866378
07/08/15 03:56 AM
07/08/15 03:56 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Puttin my boys car back together and will need a new clutch. car is a 68 coronet with 440 approximatly 390ish HP and has 143 tooth flywheel drilled for 10.5 or 11 inch. It will see track time but mostly street. What will work with sticky tires and still be streetable?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Clutch for b body with 440
[Re: mikeysmopars]
#1866444
07/08/15 10:43 AM
07/08/15 10:43 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Puttin my boys car back together and will need a new clutch. car is a 68 coronet with 440 approximatly 390ish HP and has 143 tooth flywheel drilled for 10.5 or 11 inch. It will see track time but mostly street. What will work with sticky tires and still be streetable? http://m.summitracing.com/parts/mcl-360951I like this McLeod setup. Works with a 10.95 " disc. It'll work well for your HP range.
[Re: mikeysmopars]
#1866474
07/08/15 11:49 AM
07/08/15 11:49 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I run a Center Force dual friction 11 inch behind my B body 440 with over 550 HP.Been in for years and still hooks great.Plus it has a light pedal.Some will say a diaphram isnt good for recing.Ive never had a problem shifting at 7000 many times.Its been street /strip.Rocky
Chrysler Firepower
[Re: therocks]
#1866485
07/08/15 12:05 PM
07/08/15 12:05 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I run a Center Force dual friction 11 inch behind my B body 440 with over 550 HP.Been in for years and still hooks great.Plus it has a light pedal.Some will say a diaphram isnt good for recing.Ive never had a problem shifting at 7000 many times.Its been street /strip.Rocky I agree. Great set up. I don't rev. to 7000 on purpose, but the engine has been there unintentionally from time to time with no issues. I would recommend CFDF.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
