Clutch for b body with 440 #1866378
07/08/15 03:56 AM
07/08/15 03:56 AM
fresno ca
mikeysmopars Offline OP
fresno ca
Puttin my boys car back together and will need a new clutch.
car is a 68 coronet with 440 approximatly 390ish HP and has 143 tooth flywheel drilled for 10.5 or 11 inch. It will see track time but mostly street.
What will work with sticky tires and still be streetable?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Clutch for b body with 440 [Re: mikeysmopars] #1866429
07/08/15 10:03 AM
07/08/15 10:03 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
18-spline or 23-spline trans ???
Re: Clutch for b body with 440 [Re: mikeysmopars] #1866444
07/08/15 10:43 AM
07/08/15 10:43 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://m.summitracing.com/parts/mcl-360951
I like this McLeod setup. Works with a 10.95
" disc. It'll work well for your HP range.
Re: Clutch for b body with 440 [Re: mikeysmopars] #1866474
07/08/15 11:49 AM
07/08/15 11:49 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a Center Force dual friction 11 inch behind my B body 440 with over 550 HP.Been in for years and still hooks great.Plus it has a light pedal.Some will say a diaphram isnt good for recing.Ive never had a problem shifting at 7000 many times.Its been street /strip.Rocky
Chrysler Firepower
Re: Clutch for b body with 440 [Re: therocks] #1866485
07/08/15 12:05 PM
07/08/15 12:05 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I agree. Great set up. I don't rev. to 7000 on purpose, but the engine has been there unintentionally from time to time with no issues. I would recommend CFDF.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Clutch for b body with 440 [Re: 68LAR] #1866550
07/08/15 01:35 PM
07/08/15 01:35 PM
dogdays Offline
dogdays  Offline
Absolutely, the 10.95" setup.
R.
Re: Clutch for b body with 440 [Re: mikeysmopars] #1866827
07/08/15 07:32 PM
07/08/15 07:32 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I run the Centerforce dual friction and it works very good, but, expect to play with the clutch linkage. It requires more throw than the stock clutch did to get it to fully disengage with proper throwout bearing space at rest.
Re: Clutch for b body with 440 [Re: Cudajon] #1866877
07/08/15 09:04 PM
07/08/15 09:04 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I've been running a South Bend Clutch "DXD" for several years, with no complaints.
Is that 390hp at the wheels or the flywheel?
Re: Clutch for b body with 440 [Re: 440trk] #1866893
07/08/15 09:20 PM
07/08/15 09:20 PM
fresno ca
fresno ca
flywheel HP, Engine has 6pack replacement pistons, cam is hughs 536 lifthydrolic,Stock 452 heads and has a rpm intake with 750 DP, HP is just estimated but i should be close. My dilema is I have never run a diaphram pressure plate myself though have heard many good things about them. I like the idea of the Dual friction Mcleod with the lever style pressure plate but i'm open to input as many have already. thumbs
Re: Clutch for b body with 440 [Re: mikeysmopars] #1874838
07/21/15 01:09 AM
07/21/15 01:09 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
For what it's worth, my DXD is a 3 finger Borg & Beck style. The guys at South Bend were awesome...very friendly and great customer service! If you tell them what you want to do, they will make you the clutch you need. I figured if they can build a clutch to harness 1200+ lb ft of modified Cummins diesel, a naturally asperated 440 should be no problem. So far, I'm happy with my choice. smile
