Anyone with Corbeau 3-point harness belts in their old car? #1852249
06/19/15 12:10 AM
06/19/15 12:10 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am ruling out a cage, at least at this point, for various reasons in my Barracuda. Part of that is keeping a relatively stock interior, which leads into trying to find a better seat harness that will keep me in the seat.
I ran the retractable version of these harnesses in my Jeep, liked them ok, but wanted to go to the double-release version [linked]. My primary concern is with the geometry of the stock E-body buckets, they aren't very conducive to aftermarket harnesses.
http://corbeau.com/other/harness-belts/3-point-double-release-harness-belt.html
For those not familiar with the E-body buckets:
I am looking to see if anyone here has these in their car. I don't think the side support on the stock seats [there isn't any] is enough to do much with, but it's worth asking.
The theory is to anchor the top down between the back seat cushions, if I need access to the back or someone needs to ride back there, I can unbuckle the Corbeau harness and run the lap belts without any trouble at all.
Thanks for the input!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1852292
06/19/15 12:46 AM
06/19/15 12:46 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"Stock interior look, keep you in the seat better". You left out any reference to safety of the occupant. I don't see what you have pictured as any solution other then stock look. The between the seats mounting angle is a huge compromise, you know that already, the width and shape of the seat back will only induce the v belt to slip off and down, and I'm on record many times of the risk of using any shoulder harness without a 5th+ belt. You need to widen your options, this is not it, IMO.
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1852337
06/19/15 02:07 AM
06/19/15 02:07 AM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
The issue with these old cars is there's nothing to brace your legs on. Then I'm hanging on the steering wheel trying to stay up in the seat.
its kinda gimmicky, but i know guys that use this with OK results. not safety, but for autox stock classes where you cant change your seat, just to keep you in your seat:
http://www.jegs.com/i/G-Force/471/4290BU...CFdgNgQodeiYA3A
a three point is not going to work without a passthrough/adj headrest posts or something to locate the shoulder straps. Then you need a harness bar so you don't compress your spine (and anchor to) if you actually hit something. Otherwise i would only consider a three point for autox pylons.
one of you enterprising types need to make a passthrough bezel in the manner the SRT4 ACR seat bezels that are no longer available. EDIT apparently my google foo is weak and ive been looking for the wrong thing. search "seat grommets". like such http://www.c5racer.com/catalog/c5-c6-z06...ness-belts.html shouldnt be terrible to install again you need belt higher than your shoulders.
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1852407
06/19/15 09:13 AM
06/19/15 09:13 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Between the seat anchoring could be moved to the package tray area [with proper support] if necessary. But the V not being constrained on the seat back was my biggest concerned and just wanted to hear it verified.
The belt pass-throughs may be a pretty reasonable compromise and a way to put a better harness in the car.
2020 RAM 1500
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1852442
06/19/15 11:42 AM
06/19/15 11:42 AM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
Mike,
I've seen NHRA racers bring there stock seats to an upholstery shop and have them punch the holes into the tops of the seat hack where the shoulder belts run. It looked awesome!
1971 6.1 Gen III Hemi Duster
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1852544
06/19/15 02:46 PM
06/19/15 02:46 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The shoulder harnesses need to be mounted above the shoulders, if not, when you get in a rapid deceleration event you will get serious spinal compression. In basic terms if you get in a head on collision, you will hurt your back seriously due to the belts. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1852597
06/19/15 04:02 PM
06/19/15 04:02 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can make a harness bar that mounts to the backseat seatbelt anchors and then run your front harnesses around that. I think Mr. Angry has one of those is his Charger or Daytona.
Mopar to the bone!!!
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: 72Swinger] #1856293
06/24/15 11:55 PM
06/24/15 11:55 PM
IN
ahy Offline
ahy  Offline
IN
Not an expert on the belts... though I'm thinking of the backseat anchored 3 point. On the seats... I think the stock E body seats basically suck for both handling and distance driving. No side support and weak back support. For OE resto, no question fix up the stockers. For handling you really need a better seat. My solution was Scat rally seats. Good side support and good back support. Available at reasonable cost from Summit with matching brackets for an "E". Just have to hacksaw off 2 of the 3 mounting locations to get the seat at the right height. Not a full race seat but 1000% better than stock. Also does not look out of place too much in a 70's car. Comfortable as well for long drives for me at least (eg. IL to CA in 3 days, back in the same time).
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1856340
06/25/15 12:58 AM
06/25/15 12:58 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
As far as belts you can easily convert to retractable 3 points just like New cars have. Wesco is what mine are.
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: 72Swinger] #1860213
06/30/15 02:55 AM
06/30/15 02:55 AM
Dr Dave Offline
Dr Dave  Offline
We're the wesco belts a direct bolt in?
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1860214
06/30/15 02:59 AM
06/30/15 02:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes as long as you have the roof bolts for the shoulder belts. My car is a 72 and had them. If you car only has factory lap belts then you cant use the 3 point retractables.
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: 72Swinger] #1861023
07/01/15 01:41 AM
07/01/15 01:41 AM
Dr Dave Offline
Dr Dave  Offline
'71 Cuda. The headliner has been replaced and there are no clips or belts visible above the door but I'm thinking all '71's had the shoulder belt, so the mounting plate should be there. Am I right?
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1861036
07/01/15 03:07 AM
07/01/15 03:07 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think so, I think even 69's had them.
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: 72Swinger] #1861039
07/01/15 03:27 AM
07/01/15 03:27 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
build date on mine was 10/69 and it has the plates
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: ntstlgl1970] #1861531
07/01/15 09:17 PM
07/01/15 09:17 PM
Dr Dave Offline
Dr Dave  Offline
Did you use an extender strap from the top mount to the shoulder belt and how long?
Thanks!
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1861625
07/01/15 10:58 PM
07/01/15 10:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
There are I think a standard length extended upper sash that IIRC is 8-9" long. Wesco brand.
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1861637
07/01/15 11:04 PM
07/01/15 11:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The van ones are what're in my car. Only difference is they have the 8" upper sash........... http://wescoperformance.stores.yahoo.net/3poresebewil.html
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1861650
07/01/15 11:13 PM
07/01/15 11:13 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The XV 3-points look pretty reasonably priced, might go down that route for now.
2020 RAM 1500
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: GoodysGotaCuda] #1864704
07/05/15 11:08 PM
07/05/15 11:08 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Tom Quad ran the shoulder anchor to the package tray with a reinforcement plate on the underside of the package tray inside the trunk on the Black n Blue Charger. Somewhere on the board is a picture of how he mounted the belts.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1230869/2.html
Re: Anyone with Corbeau 3-point harness belts in their old car? [Re: PHJ426] #1865314
07/06/15 06:38 PM
07/06/15 06:38 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I want to do this for my back seat folks. Also would love a 4 point for the center rear position.
