Anyone with Corbeau 3-point harness belts in their old car?
#1852249
06/19/15 12:10 AM
06/19/15 12:10 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am ruling out a cage, at least at this point, for various reasons in my Barracuda. Part of that is keeping a relatively stock interior, which leads into trying to find a better seat harness that will keep me in the seat. I ran the retractable version of these harnesses in my Jeep, liked them ok, but wanted to go to the double-release version [linked]. My primary concern is with the geometry of the stock E-body buckets, they aren't very conducive to aftermarket harnesses. http://corbeau.com/other/harness-belts/3-point-double-release-harness-belt.htmlFor those not familiar with the E-body buckets: I am looking to see if anyone here has these in their car. I don't think the side support on the stock seats [there isn't any] is enough to do much with, but it's worth asking. The theory is to anchor the top down between the back seat cushions, if I need access to the back or someone needs to ride back there, I can unbuckle the Corbeau harness and run the lap belts without any trouble at all. Thanks for the input!
Re: Anyone with Corbeau 3-point harness belts in their old car?
[Re: GoodysGotaCuda]
#1852292
06/19/15 12:46 AM
06/19/15 12:46 AM
Posts: 22,696 Bitopia
jcc
Bitopia
"Stock interior look, keep you in the seat better". You left out any reference to safety of the occupant. I don't see what you have pictured as any solution other then stock look. The between the seats mounting angle is a huge compromise, you know that already, the width and shape of the seat back will only induce the v belt to slip off and down, and I'm on record many times of the risk of using any shoulder harness without a 5th+ belt. You need to widen your options, this is not it, IMO.
#1852337
06/19/15 02:07 AM
06/19/15 02:07 AM
Posts: 106 Central IL
Trojmn
Central IL
The issue with these old cars is there's nothing to brace your legs on. Then I'm hanging on the steering wheel trying to stay up in the seat. its kinda gimmicky, but i know guys that use this with OK results. not safety, but for autox stock classes where you cant change your seat, just to keep you in your seat: http://www.jegs.com/i/G-Force/471/4290BU...CFdgNgQodeiYA3Aa three point is not going to work without a passthrough/adj headrest posts or something to locate the shoulder straps. Then you need a harness bar so you don't compress your spine (and anchor to) if you actually hit something. Otherwise i would only consider a three point for autox pylons. one of you enterprising types need to make a passthrough bezel in the manner the SRT4 ACR seat bezels that are no longer available. EDIT apparently my google foo is weak and ive been looking for the wrong thing. search "seat grommets". like such http://www.c5racer.com/catalog/c5-c6-z06...ness-belts.html shouldnt be terrible to install again you need belt higher than your shoulders.
#1852442
06/19/15 11:42 AM
06/19/15 11:42 AM
Posts: 751 Saint Peters, MO
Brian
Saint Peters, MO
Mike,
I've seen NHRA racers bring there stock seats to an upholstery shop and have them punch the holes into the tops of the seat hack where the shoulder belts run. It looked awesome!
1971 6.1 Gen III Hemi Duster
#1852544
06/19/15 02:46 PM
06/19/15 02:46 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The shoulder harnesses need to be mounted above the shoulders, if not, when you get in a rapid deceleration event you will get serious spinal compression. In basic terms if you get in a head on collision, you will hurt your back seriously due to the belts. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
#1852597
06/19/15 04:02 PM
06/19/15 04:02 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You can make a harness bar that mounts to the backseat seatbelt anchors and then run your front harnesses around that. I think Mr. Angry has one of those is his Charger or Daytona.
Mopar to the bone!!!
#1856340
06/25/15 12:58 AM
06/25/15 12:58 AM
72Swinger
Nebraska
As far as belts you can easily convert to retractable 3 points just like New cars have. Wesco is what mine are.
#1860214
06/30/15 02:59 AM
06/30/15 02:59 AM
72Swinger
Nebraska
Yes as long as you have the roof bolts for the shoulder belts. My car is a 72 and had them. If you car only has factory lap belts then you cant use the 3 point retractables.
#1861036
07/01/15 03:07 AM
07/01/15 03:07 AM
72Swinger
Nebraska
I think so, I think even 69's had them.
#1861625
07/01/15 10:58 PM
07/01/15 10:58 PM
72Swinger
Nebraska
There are I think a standard length extended upper sash that IIRC is 8-9" long. Wesco brand.
[Re: PHJ426]
#1865314
07/06/15 06:38 PM
07/06/15 06:38 PM
72Swinger
Nebraska
I want to do this for my back seat folks. Also would love a 4 point for the center rear position.
