4 speed shifter-- super shifter or competition + #1858032
06/27/15 10:48 AM
06/27/15 10:48 AM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
Had trans out and I'm putting it back in
Found super shifter in the barn so trying to deside which?
had competition plus and shifted fine...
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858040
06/27/15 11:05 AM
06/27/15 11:05 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think the only difference is the reverse lockout.
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858043
06/27/15 11:10 AM
06/27/15 11:10 AM
Sharpsburg Maryland
Sharpsburg Maryland
I think the super shifter has a shorter throw -looks like where the stick is bolted on is further from the main bolt- (pivot point)??
it goes in a 64 belvedere w/ long stick I think it would work
might just try it?
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858110
06/27/15 01:20 PM
06/27/15 01:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I remember I used the Super Shifter back in my 4-speed Dart that I bracket raced back in the late 70's and early 80's. Even back then I was one of the few stick cars bracket racing as most were auto's. I really liked the Super Shifter and could really slam the gears fast using the Super Shifter. I remember a guy in a Camaro came up and asked me what I ran after I beat him (no 60 fts back then and individual time cards) as he had run 11.88 on his 11.88 dail in his auto Camaro. I ran 12.18 on my 12.18 dail in my 4-speed 340 Dart and beat him as it was a semi-final round. But you did not get reaction times or 60 ft times back then. And that was using that nice Super Shifter which I really liked. Oh and Pro eliminator was 11.00 to 12.49 at that time. Ron
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858112
06/27/15 01:23 PM
06/27/15 01:23 PM
I've never used a Super Shifter in a B body, in the 1967 and later A bodys you have to cut the trans crossmeber to clear the shifting rods so they don't rub on it work Look at your rods first to see if they are straight with reinforcing sleeves on them lke the A bodys have, if so you may have the same issues on yours scope Hopefully not up
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858120
06/27/15 01:36 PM
06/27/15 01:36 PM
Sharpsburg Maryland
Sharpsburg Maryland
Could'nt you use the super shifter with the comp. rods
looks like the holes in the shifter levers are the same??
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858389
06/27/15 09:24 PM
06/27/15 09:24 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
The Super Shifter is probably the best H-pattern shifter ever made. You shouldn't have any problem using the HD linkage in B-body because it mounts in front of the crossmember.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 4 speed shifter-- super shifter or competition + [Re: fourgearsavoy] #1858680
06/28/15 03:09 AM
06/28/15 03:09 AM
Gus beer
My bad blush, I have worked and built early B body 4 speed cars years ago, Gus it correct on this up I'm getting ready to build and assemble a 1966 Dodge Coronet Deluxe, changing from a slant six with three on the tree to a 440 with a NP833 O.D. trans and OEM cheap shifter out of a pick up or van confused OP, maybe I'll be in the market for the shifter you don't use work If you want to sell it, that is up
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858700
06/28/15 06:51 AM
06/28/15 06:51 AM
sweden
sshemi Offline
sshemi  Offline
sweden
The super shifter is VERY close in measures to the oem bbody shifter.
So it can be used in the stock position and with stock shift rods if bushings/reducers are used in shifter arms.
I would say that comp + and super shifter are similar in design but super shifter seems beefier and will probably last longer.
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858704
06/28/15 07:49 AM
06/28/15 07:49 AM
Sharpsburg Maryland
Sharpsburg Maryland
Thanks everyone
I'll try the super
Cab i'd like to hold onto the spare--alot of buddies & I swap parts all the time
Now I have a problem with high gear not engaging when lever is in detent??
had the trans face plated and seems like the high gear plate is too far away--to close to head gear??
goin to have to call liberty tomorrow mornin.
Re: 4 speed shifter-- super shifter or competition + [Re: Cab_Burge] #1858852
06/28/15 01:40 PM
06/28/15 01:40 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Gus beer
I know a guy with a bunch of b-body four speed stuff in his attic...
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858853
06/28/15 01:41 PM
06/28/15 01:41 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted By 440farmer
Thanks everyone
I'll try the super
Do you have the correct 3-4 non-offset shift fork?
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858857
06/28/15 01:45 PM
06/28/15 01:45 PM
Sharpsburg Maryland
Sharpsburg Maryland
Yeah got a couple sets
I think I'm ok on the shifter
but I got bigger fish to fry trin to figure out this high gear thing!
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858865
06/28/15 01:53 PM
06/28/15 01:53 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Are you useing the offset 3-4 fork?
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858883
06/28/15 02:14 PM
06/28/15 02:14 PM
Sharpsburg Maryland
Sharpsburg Maryland
did'nt know there was such a thing
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1858938
06/28/15 03:45 PM
06/28/15 03:45 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Stock wont work. Liberty have them.
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1859592
06/29/15 01:01 PM
06/29/15 01:01 PM
Sharpsburg Maryland
Sharpsburg Maryland
Just got of the phone with Liberty
and ordered one thanks for the help!
Re: 4 speed shifter-- super shifter or competition + [Re: 440farmer] #1860222
06/30/15 03:22 AM
06/30/15 03:22 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Glad i could help.
