Re: 4 speed shifter-- super shifter or competition +
[Re: 440farmer]
#1858110
06/27/15 01:20 PM
06/27/15 01:20 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I remember I used the Super Shifter back in my 4-speed Dart that I bracket raced back in the late 70's and early 80's. Even back then I was one of the few stick cars bracket racing as most were auto's. I really liked the Super Shifter and could really slam the gears fast using the Super Shifter. I remember a guy in a Camaro came up and asked me what I ran after I beat him (no 60 fts back then and individual time cards) as he had run 11.88 on his 11.88 dail in his auto Camaro. I ran 12.18 on my 12.18 dail in my 4-speed 340 Dart and beat him as it was a semi-final round. But you did not get reaction times or 60 ft times back then. And that was using that nice Super Shifter which I really liked. Oh and Pro eliminator was 11.00 to 12.49 at that time. Ron
[Re: 440farmer]
#1858112
06/27/15 01:23 PM
06/27/15 01:23 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I've never used a Super Shifter in a B body, in the 1967 and later A bodys you have to cut the trans crossmeber to clear the shifting rods so they don't rub on it Look at your rods first to see if they are straight with reinforcing sleeves on them lke the A bodys have, if so you may have the same issues on yours Hopefully not
[Re: 440farmer]
#1858389
06/27/15 09:24 PM
06/27/15 09:24 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
The Super Shifter is probably the best H-pattern shifter ever made. You shouldn't have any problem using the HD linkage in B-body because it mounts in front of the crossmember. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1858680
06/28/15 03:09 AM
06/28/15 03:09 AM
Cab_Burge
The Super Shifter is probably the best H-pattern shifter ever made. You shouldn't have any problem using the HD linkage in B-body because it mounts in front of the crossmember. Gus My bad , I have worked and built early B body 4 speed cars years ago, Gus it correct on this I'm getting ready to build and assemble a 1966 Dodge Coronet Deluxe, changing from a slant six with three on the tree to a 440 with a NP833 O.D. trans and OEM cheap shifter out of a pick up or van OP, maybe I'll be in the market for the shifter you don't use If you want to sell it, that is
[Re: Cab_Burge]
#1858852
06/28/15 01:40 PM
06/28/15 01:40 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
The Super Shifter is probably the best H-pattern shifter ever made. You shouldn't have any problem using the HD linkage in B-body because it mounts in front of the crossmember. Gus My bad , I have worked and built early B body 4 speed cars years ago, Gus it correct on this I'm getting ready to build and assemble a 1966 Dodge Coronet Deluxe, changing from a slant six with three on the tree to a 440 with a NP833 O.D. trans and OEM cheap shifter out of a pick up or van OP, maybe I'll be in the market for the shifter you don't use If you want to sell it, that is I know a guy with a bunch of b-body four speed stuff in his attic...
[Re: 440farmer]
#1858853
06/28/15 01:41 PM
06/28/15 01:41 PM
Jeremiah
Rogue River, OR
Thanks everyone I'll try the super Cab i'd like to hold onto the spare--alot of buddies & I swap parts all the time
Now I have a problem with high gear not engaging when lever is in detent?? had the trans face plated and seems like the high gear plate is too far away--to close to head gear?? goin to have to call liberty tomorrow mornin. Do you have the correct 3-4 non-offset shift fork?
[Re: 440farmer]
#1860222
06/30/15 03:22 AM
06/30/15 03:22 AM
Posts: 2,128 sweden
sshemi
sweden
