Dzus fasteners---how many? where to get? #1855783
06/24/15 09:50 AM
06/24/15 09:50 AM
west palm beach, florida
modelmakerinc Offline OP
As the title says, I am going to use 1/4 turn Fasteners on my Coronet bracket car, but I find them to be pretty expensive for what that are.
Where is the best place to get a good deal on a couple dozen, also how many used is a matter of opinion but what is a good amount across the front, sides and back of the hood.
Fiberglass lift off from AAR for a 67 Coronet.
Thanks in advance. Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1855802
06/24/15 11:08 AM
06/24/15 11:08 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Any of the big race car shops have them. I usually call RJ for 90% of my stuff like that. How many you will get lots of debate. I ususlly go with on a really lightweight/thin hood 1 every 12" or so. If its a really thick/rigid hood I have gotten by with 16" or so apart.
http://www.rjracecars.com/
One day I will have something cool here.
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1855805
06/24/15 11:19 AM
06/24/15 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You can get them at Summit... also.. they make them in
different lengths so know what you need(might buy a couple
of different lengths to test).. I do about the same with
12" to 14" spread... but hood design will make the difference
if air can get under the front lip
wave
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1855812
06/24/15 11:34 AM
06/24/15 11:34 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Without buying several lengths, is there a way to determine the length before purchasing?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1855819
06/24/15 11:53 AM
06/24/15 11:53 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
http://www.jegs.com/i/JEGS+Performance+Products/555/82270/10002/-1
This is what I used .
I did have to buy one more dzus and plate for the back of the hood behind the scoop.
Re: Dzus fasteners---how many? where to get? [Re: DemonDust] #1855859
06/24/15 01:01 PM
06/24/15 01:01 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
One way of figuring out the length Dzus you need, is to first install the mounting plates and drill the holes in the hood. Then, using the "butt end" of vernier calipers, measure from the top surface of the hood to the middle of the spring.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1855914
06/24/15 02:15 PM
06/24/15 02:15 PM
Thanks guys, I didn't think about needing different lengths so guess I need to have my hood in hand before I buy the fasteners.
OK, now to wait on the hood being finished and shipped.
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1855921
06/24/15 02:32 PM
06/24/15 02:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If I was mounting a new hood today I think I would do some reading up on these. I kinda like this idea.
http://www.q-latch.com/index.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dzus fasteners---how many? where to get? [Re: modelmakerinc] #1856003
06/24/15 04:13 PM
06/24/15 04:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
On typical race thickness glass body panels, I use a #6 ejector, .500 long and a #6, .375 high spring. Lots of options on the spring tabs/mounts. If your parts are thicker street weight or thin carbon, you may want to adjust a step one way or the other on the fastener length. There are tools to adjust the spring height once it is installed in order to fine tune the tension on the fastener. A good investment even for one hood install. Unless you are buying in quantity, expect to pay $2.30 to 2.60 or so for the buttons and .70 to 1.00 for springs. 17 buttons on my hood. Little more than a foot apart on the sides and the back. Little less than a foot across the front.
A little far for you to drive or I'd tell you to swing by and pick some up.
Re: Dzus fasteners---how many? where to get? [Re: pittsburghracer] #1856011
06/24/15 04:21 PM
06/24/15 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is what I have on the front of my Rampage.. it was a lift
off hood but I built it as a hinged set up and a pair of those
on the front... I've only been 105 mph so far but they are
holding it down nicely
wave
Re: Dzus fasteners---how many? where to get? [Re: MR_P_BODY] #1856126
06/24/15 07:45 PM
06/24/15 07:45 PM
oregon
greendart408 Offline
oregon
I get my zues fasteners from Behrent's performance warehouse, they are Allen head, you can get them in alum or steel, I like them way better than the standard zues.
