Re: Dzus fasteners---how many? where to get?
[Re: modelmakerinc]
#1855802
06/24/15 11:08 AM
06/24/15 11:08 AM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Any of the big race car shops have them. I usually call RJ for 90% of my stuff like that. How many you will get lots of debate. I ususlly go with on a really lightweight/thin hood 1 every 12" or so. If its a really thick/rigid hood I have gotten by with 16" or so apart. http://www.rjracecars.com/
One day I will have something cool here.
[Re: modelmakerinc]
#1855805
06/24/15 11:19 AM
06/24/15 11:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You can get them at Summit... also.. they make them in different lengths so know what you need(might buy a couple of different lengths to test).. I do about the same with 12" to 14" spread... but hood design will make the difference if air can get under the front lip
[Re: DemonDust]
#1855859
06/24/15 01:01 PM
06/24/15 01:01 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Without buying several lengths, is there a way to determine the length before purchasing? One way of figuring out the length Dzus you need, is to first install the mounting plates and drill the holes in the hood. Then, using the "butt end" of vernier calipers, measure from the top surface of the hood to the middle of the spring.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: modelmakerinc]
#1855921
06/24/15 02:32 PM
06/24/15 02:32 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If I was mounting a new hood today I think I would do some reading up on these. I kinda like this idea. http://www.q-latch.com/index.html
[Re: modelmakerinc]
#1856003
06/24/15 04:13 PM
06/24/15 04:13 PM
Posts: 11,579 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
On typical race thickness glass body panels, I use a #6 ejector, .500 long and a #6, .375 high spring. Lots of options on the spring tabs/mounts. If your parts are thicker street weight or thin carbon, you may want to adjust a step one way or the other on the fastener length. There are tools to adjust the spring height once it is installed in order to fine tune the tension on the fastener. A good investment even for one hood install. Unless you are buying in quantity, expect to pay $2.30 to 2.60 or so for the buttons and .70 to 1.00 for springs. 17 buttons on my hood. Little more than a foot apart on the sides and the back. Little less than a foot across the front.
A little far for you to drive or I'd tell you to swing by and pick some up.
[Re: pittsburghracer]
#1856011
06/24/15 04:21 PM
06/24/15 04:21 PM
MR_P_BODY
That is what I have on the front of my Rampage.. it was a lift off hood but I built it as a hinged set up and a pair of those on the front... I've only been 105 mph so far but they are holding it down nicely
[Re: MR_P_BODY]
#1856126
06/24/15 07:45 PM
06/24/15 07:45 PM
Posts: 1,073 oregon
greendart408
oregon
I get my zues fasteners from Behrent's performance warehouse, they are Allen head, you can get them in alum or steel, I like them way better than the standard zues.
