Oil Filter #1844228
06/08/15 02:53 PM
06/08/15 02:53 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
I went to Walmart to get oil and filter for my 70 Dart with a 318. I saw the black mopar oil filters I asked the sales person which one will fit my car and they did not know. The catalog did not go back that far. It looked like the one # M0-090 would fit but I'm not sure. Can anyone tell me if it will or what is the correct #. Thanks for the Help
Re: Oil Filter [Re: 70dart318] #1844261
06/08/15 03:26 PM
06/08/15 03:26 PM
AndyF Online content
AndyF  Online Content
Almost all of the "classic" Mopar engines can use the same oil filter including some of the more modern engines. I've heard that Mopar changed over to a metric thread for the oil filter in 2008 but I'm not 100% sure that is true.
If you go to the dealer they'll have a couple of different oil filters that fit everything. The small "tea cup" size and the larger standard size.
Eberg did a classic article on oil filters years ago. You might be able to find it posted somewhere.
Re: Oil Filter [Re: 70dart318] #1845436
06/09/15 11:44 PM
06/09/15 11:44 PM
BDW Online content
BDW  Online Content
Re: Oil Filter [Re: 70dart318] #1846505
06/11/15 11:10 AM
06/11/15 11:10 AM
gregsdart Offline
gregsdart  Offline
The Wix is the better filter by far. If you race, the 51515R is rated at about 28 gpm of oil flow before bypass, (larger filtering media, stops the big stuff) and the street 51515 filter is only 7 or 9 gpm.
Re: Oil Filter [Re: 70dart318] #1846943
06/11/15 10:14 PM
06/11/15 10:14 PM
Streetsboro,Ohio
Streetsboro,Ohio
I forgot to mention it has the 90 degree adapter and headers.
Re: Oil Filter [Re: 70dart318] #1847056
06/12/15 12:01 AM
06/12/15 12:01 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
In Purolator the short filter is L14670 and the long is L30001.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Oil Filter [Re: gregsdart] #1847185
06/12/15 05:33 AM
06/12/15 05:33 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
how can you say the Wix is the best when at a factory in the city i live in, Wix, Fram, Toyota Genuine & Purolator are all made in the same factory with the same parts? i'm not saying they make every filter for all applications, but the make a large range & it's just the last stage when they get Screenprinted is the brand for which box they get shipped off in. some filters were slightly different in construction but i was getting HP1 Fram filters that had accidentally had Toyota Genuine Screenprinting on them.
Re: Oil Filter [Re: rebel] #1847202
06/12/15 09:09 AM
06/12/15 09:09 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Absolutely false. While I don't know who makes the Toyota filter, the other 3 are most definitely not the same, and not made in the same plant.
It's Swifty! Swifty, you toad sucker!
Re: Oil Filter [Re: 70dart318] #1847267
06/12/15 11:42 AM
06/12/15 11:42 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes the 090 is the one you want, I use them on my Dart and 04 Intrepid. The 899 is for later vehicles.
Re: Oil Filter [Re: 70dart318] #1847296
06/12/15 12:30 PM
06/12/15 12:30 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I was using the 090 and the Wix #51068 on my Diplomat with headers and 90 degree adapter,until I did a filter relocation. Now I use the huge Baldwin BT237.
Facts are stubborn things.
Re: Oil Filter [Re: zrxkawboy] #1847599
06/12/15 07:53 PM
06/12/15 07:53 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
umm sorry to dissappoint you but they are down here. companies outsource work to where ever is cheap & down under has a filter manufacturing plant that makes multiple brands. the filtration media might change from filter to filter but they're basicly the same.
Re: Oil Filter [Re: 70dart318] #1847646
06/12/15 08:33 PM
06/12/15 08:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Oil filters are not basically the same internally. There is a lot of difference inside if you have ever looked at the posts of them broken open.
Re: Oil Filter [Re: stumpy] #1847836
06/13/15 12:52 AM
06/13/15 12:52 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Bingo. Cut open a few, or look for images in the Oil Filter forum at BITOG. Lots of pics of open filters there. Wix, Fram, and Purolator are very different, construction-wise.
