Re: Oil Filter
[Re: 70dart318]
#1846505
06/11/15 11:10 AM
06/11/15 11:10 AM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The Wix is the better filter by far. If you race, the 51515R is rated at about 28 gpm of oil flow before bypass, (larger filtering media, stops the big stuff) and the street 51515 filter is only 7 or 9 gpm.
Re: Oil Filter
[Re: 70dart318]
#1847056
06/12/15 12:01 AM
06/12/15 12:01 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
In Purolator the short filter is L14670 and the long is L30001.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Oil Filter
[Re: gregsdart]
#1847185
06/12/15 05:33 AM
06/12/15 05:33 AM
Posts: 4,647 aotearoa
rebel
aotearoa
The Wix is the better filter by far. how can you say the Wix is the best when at a factory in the city i live in, Wix, Fram, Toyota Genuine & Purolator are all made in the same factory with the same parts? i'm not saying they make every filter for all applications, but the make a large range & it's just the last stage when they get Screenprinted is the brand for which box they get shipped off in. some filters were slightly different in construction but i was getting HP1 Fram filters that had accidentally had Toyota Genuine Screenprinting on them.
Re: Oil Filter
[Re: rebel]
#1847202
06/12/15 09:09 AM
06/12/15 09:09 AM
Posts: 905 SD
zrxkawboy
SD
how can you say the Wix is the best when at a factory in the city i live in, Wix, Fram, Toyota Genuine & Purolator are all made in the same factory with the same parts? Absolutely false. While I don't know who makes the Toyota filter, the other 3 are most definitely not the same, and not made in the same plant.
It's Swifty! Swifty, you toad sucker!
Re: Oil Filter
[Re: 70dart318]
#1847296
06/12/15 12:30 PM
06/12/15 12:30 PM
Posts: 15,879 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I was using the 090 and the Wix #51068 on my Diplomat with headers and 90 degree adapter,until I did a filter relocation. Now I use the huge Baldwin BT237.
Facts are stubborn things.
Re: Oil Filter
[Re: zrxkawboy]
#1847599
06/12/15 07:53 PM
06/12/15 07:53 PM
rebel
aotearoa
how can you say the Wix is the best when at a factory in the city i live in, Wix, Fram, Toyota Genuine & Purolator are all made in the same factory with the same parts? Absolutely false. While I don't know who makes the Toyota filter, the other 3 are most definitely not the same, and not made in the same plant. umm sorry to dissappoint you but they are down here. companies outsource work to where ever is cheap & down under has a filter manufacturing plant that makes multiple brands. the filtration media might change from filter to filter but they're basicly the same.
Re: Oil Filter
[Re: stumpy]
#1847836
06/13/15 12:52 AM
06/13/15 12:52 AM
Posts: 905 SD
zrxkawboy
SD
Oil filters are not basically the same internally. There is a lot of difference inside if you have ever looked at the posts of them broken open. Bingo. Cut open a few, or look for images in the Oil Filter forum at BITOG. Lots of pics of open filters there. Wix, Fram, and Purolator are very different, construction-wise.
