Intake machining question! #1843419
06/07/15 02:14 PM
06/07/15 02:14 PM
Oak Harbor, WA
W
Wicked49670dart Online mad OP
Wicked49670dart  Online Mad OP
W
Oak Harbor, WA
Hey Guys, I'm reassembling my motor after freshening it up and had the heads resurfaced for the second time. Now the intake needs to be machined because the port and bolt hole alignment is off. Basically the intake is about .030 on each side of the head to high, and this is with the gasket in place. What is the procedure to figure how much of the intake surface to remove on each side. Do I take half of the amount .015 off each side and see how it fits? What is the correct way to do this?
Also can anybody recommend somewhere in Washington state to get this done? Thanks Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Intake machining question! [Re: Wicked49670dart] #1843842
06/07/15 11:32 PM
06/07/15 11:32 PM
USA
B3RE Offline
B3RE  Offline
USA
Rather than try to explain it and do all the typing, here is a link that will do give you the formulas.
http://victorylibrary.com/mopar/intake-mill-c.htm
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Intake machining question! [Re: Wicked49670dart] #1843923
06/08/15 01:15 AM
06/08/15 01:15 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
If its a single plane intake just look down the runners and you should see how much its off . Also set in on without gaskets and if it looks close have it milled whatever the gasket thickness is.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Intake machining question! [Re: Wicked49670dart] #1843928
06/08/15 01:28 AM
06/08/15 01:28 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Mopar SB manual says that it's .0095 for every .010 taken off the head surface. If you can mill the intake side of the head, that is better so the intake isn't matched only to those heads.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Intake machining question! [Re: herkamer] #1844033
06/08/15 09:08 AM
06/08/15 09:08 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I am sure you are aware of it, but if you mill the intake, then it can only be used for that combination. I would try to double up on gaskets or a combination of gaskets to get the thickness you need, if possible. Just my 2 cents.
Re: Intake machining question! [Re: Dodgeguy101] #1844180
06/08/15 01:55 PM
06/08/15 01:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Check the port alignment and the manifold fit at the top and bottom of each corner.If it looks good just remove a little of the hole with a diegrinder to get the bolts to clear before you cut the manifold.If you have a good alignment and clamp on the gasket you shouldn't have an issue.Try this first before you cut.Put a thin layer of grease on the gaskets,bolt the manifold down,then remove it and you will see if you have good port alignment and clamp.
Re: Intake machining question! [Re: B G Racing] #1844732
06/09/15 01:15 AM
06/09/15 01:15 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks for the help! Matt
