H Beam Rods #1838640
06/01/15 01:11 PM
06/01/15 01:11 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Interesting side by side of a Scat H Beam vs an Offshore H Beam that I can get. Its hard to spot in the images but the Scat is 100 grams heavier.
T & K Performance
Re: H Beam Rods [Re: ChevyTS] #1838681
06/01/15 01:45 PM
06/01/15 01:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Damn.. look at the bevel they use for the radius
on the crank.. that looks big... then also. the area
around the crank.. one has a much larger wall.. I bought
4 sets of Eagle H-beams YEARS ago when they first came out
because they looked damn good back then... I'm still using
them on all my builds
wave
Re: H Beam Rods [Re: MR_P_BODY] #1838712
06/01/15 02:25 PM
06/01/15 02:25 PM
dogdays Offline
dogdays  Offline
They were both forged in China.
There is weight that adds strength, and weight that adds weight.........
R.
Re: H Beam Rods [Re: dogdays] #1838741
06/01/15 03:07 PM
06/01/15 03:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
I'm well aware of that
wave
Re: H Beam Rods [Re: ChevyTS] #1838772
06/01/15 03:46 PM
06/01/15 03:46 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I will post some more pics as soon as I can. I do have an Eagle rod laying around that I could weigh just for giggles.
T & K Performance
Re: H Beam Rods [Re: ChevyTS] #1838778
06/01/15 03:52 PM
06/01/15 03:52 PM
Ohio
jlatessa Online content
jlatessa  Online Content
Ohio
Which is which?
The top and left rod has much smoother transition fillets
and looks like it would more easily transfer forces to the beam.
Joe
Re: H Beam Rods [Re: MR_P_BODY] #1839578
06/02/15 10:56 AM
06/02/15 10:56 AM
NC
440Jim Offline
440Jim  Offline
NC
Are the pictures of the same side of each rod? i.e. the side with the bevel to clear crank journal radius.
It looks like one has larger radii from the ends to the beam, and different length bolts.
Mr. Chevy, can you post the big and small end weights?
Re: H Beam Rods [Re: 440Jim] #1839591
06/02/15 11:23 AM
06/02/15 11:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was assuming its the same side Jim... thats how I would
post the pics... A to A and so forth
wave
Re: H Beam Rods [Re: ChevyTS] #1839715
06/02/15 01:54 PM
06/02/15 01:54 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Sorry but the rods were not same side up. Here is another pic.
T & K Performance
Re: H Beam Rods [Re: ChevyTS] #1839858
06/02/15 04:59 PM
06/02/15 04:59 PM
kansas city mo
turbofreek Offline
turbofreek  Offline
kansas city mo
Bottom one doesnt have the clamping strength of the top one in the cap area. That smooth casting from the radius to the edge is the touching point. Also one allows oil to escape to the edges of the rod for a nice thin layer of oil to prevent side wear.
One clearly has much more detail in finish than the other. Also the pin end the bottom one looks narrow and missing the strength on the edge where the beam finishes up into the pin area.
Budget build sure 450 bucks the bottom will work.
top one will handle more abuse longer. Jmho
dont feel like typing it again
