Wheel Noise Ram 2500,,, HELP
#1836092
05/28/15 05:06 PM
05/28/15 05:06 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
2007 Dodge Ram 2500 4x4 6.7 Diesal Hearing a high pitch squeal with tire rotation,,,,but ONLY when I am making a turn,,, ( does not happen as i am going straight ) ,, only when making a turn,,, eg,,,windows down,,,at a stop sign,,make a turn about 10-15 MPH,,,and you can hear a rotational squeal, high pitch scrape sound....
I thought the front disc brake wear indicator might be close to the rotor,,,or i was down on the pad,,,,, Pads look very good,,,lots of pad left,,,,rotors are smooth ( stops fine BTW )
Can't tell if it's left or right,,,( almost sounds like both sides,,,but not sure )
Wheel bearing ? ( but wouldnt that be a issue no matter the position of the truck,,ie going straight or turning ?)
Pads moving around in the caliper ?? everything looks ok,,,at the moment,,,,
stumped on this,,,thanks for any comments,,,input.
Doug
Re: Wheel Noise Ram 2500,,, HELP
[Re: 69CHARGERMD]
#1836106
05/28/15 05:47 PM
05/28/15 05:47 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Have you jacked it up and shaken the wheels to check for play in the wheel bearings? I had to replace the RF on mine at 95k. Left one is still good. Actually a unit bearing assy., it seems to be a fairly common occurrence on these trucks. Good video on youtube showing how to replace it. Wasn't that bad of a job.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: buildanother]
#1836762
05/29/15 04:13 PM
05/29/15 04:13 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If it's your unit bearings, YouTube has demonstrations of how to use the power steering to press the old one out. Make sure to antisieze the heck out of the new one(s) before assembly.
**Photobucket sucks**
[Re: 69CHARGERMD]
#1843030
06/06/15 07:21 PM
06/06/15 07:21 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Hey Doug did you ever figure out what was wrong with your truck?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
