Wheel Noise Ram 2500,,, HELP #1836092
05/28/15 05:06 PM
05/28/15 05:06 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
2007 Dodge Ram 2500 4x4 6.7 Diesal
Hearing a high pitch squeal with tire rotation,,,,but ONLY when I am making a turn,,, ( does not happen as i am going straight ) ,, only when making a turn,,,
eg,,,windows down,,,at a stop sign,,make a turn about 10-15 MPH,,,and you can hear a rotational squeal, high pitch scrape sound....
I thought the front disc brake wear indicator might be close to the rotor,,,or i was down on the pad,,,,,
Pads look very good,,,lots of pad left,,,,rotors are smooth ( stops fine BTW )
Can't tell if it's left or right,,,( almost sounds like both sides,,,but not sure )
Wheel bearing ? ( but wouldnt that be a issue no matter the position of the truck,,ie going straight or turning ?)
Pads moving around in the caliper ?? everything looks ok,,,at the moment,,,,
stumped on this,,,thanks for any comments,,,input.
Doug
Re: Wheel Noise Ram 2500,,, HELP [Re: 69CHARGERMD] #1836106
05/28/15 05:47 PM
05/28/15 05:47 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Have you jacked it up and shaken the wheels to check for play in the wheel bearings? I had to replace the RF on mine at 95k. Left one is still good. Actually a unit bearing assy., it seems to be a fairly common occurrence on these trucks. Good video on youtube showing how to replace it. Wasn't that bad of a job.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Wheel Noise Ram 2500,,, HELP [Re: 69CHARGERMD] #1836135
05/28/15 06:57 PM
05/28/15 06:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Turning will allow a bad wheel bearing to lay over and put more stress on the hub rather than straight ahead which may be the reason you only get the noise on cornering.
Re: Wheel Noise Ram 2500,,, HELP [Re: stumpy] #1836444
05/29/15 03:17 AM
05/29/15 03:17 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Take a look at the distance between rotors and backing plates up front. Sometimes if service was done on front end recently the backing plate may have (accidently) bent against rotor. two cents..
Re: Wheel Noise Ram 2500,,, HELP [Re: buildanother] #1836762
05/29/15 04:13 PM
05/29/15 04:13 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If it's your unit bearings, YouTube has demonstrations of how to use the power steering to press the old one out. Make sure to antisieze the heck out of the new one(s) before assembly.
**Photobucket sucks**
Re: Wheel Noise Ram 2500,,, HELP [Re: 69CHARGERMD] #1843030
06/06/15 07:21 PM
06/06/15 07:21 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Hey Doug did you ever figure out what was wrong with your truck?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
