disc brake spindle question - b body #183066
01/03/09 10:20 PM
01/03/09 10:20 PM
NY NY
3
340duster340 Offline OP
NY NY
what spindles are correct for converting 70 b-body to disc brakes?
disc spindles are from 73+ b-body
are all b-body spindles the same?
what is the best way to convert b-body to disc brake using factory parts?
thanks
Re: disc brake spindle question - b body [Re: 340duster340] #183067
01/03/09 10:25 PM
01/03/09 10:25 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Sounds like you already have a good set of spindles. All the parts for the 73-74 Charger should work great for you. These spindles are slightly taller but there's no issue with using them in your application. Just make sure you use a matching master cylinder (for disk brakes) and an adjustable proportioning valve in the rear brake line.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: disc brake spindle question - b body [Re: goldduster318] #183068
01/03/09 10:51 PM
01/03/09 10:51 PM
NY NY
3
NY NY
thanks, a few other quick questions:
can someone school me on the a vs. b vs. e body spindle?
are all b spindles the same? and can a/e interchange with b?
also what years are in play here?
thanks!
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: disc brake spindle question - b body [Re: 340duster340] #183069
01/03/09 10:58 PM
01/03/09 10:58 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
70/2 B/E spindles and brakes are the same.
73/4 B are different. Taller spindle, larger bearings and different caliper mounting.
73/4 E spindles are the same as 70/2 but have larger bearings.
A body have shorter spindles than B and E.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: disc brake spindle question - b body [Re: moparmarks] #183070
01/03/09 11:05 PM
01/03/09 11:05 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
When you say " 73/4 B are different. Taller spindle, larger bearings and different caliper mounting" are you referring to slider vs. pin type caliper mount?
Re: disc brake spindle question - b body [Re: moparmarks] #183071
01/03/09 11:06 PM
01/03/09 11:06 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'73-'76 A-body disc knuckles ARE '73-'74 E-body units.
All those knuckles are the same height except the '73 and newer B/F/M/J/R body stuff.
Caliper bracket mounting holes are the same on all knuckles listed.
Re: disc brake spindle question - b body [Re: Suregrip391] #183072
01/03/09 11:10 PM
01/03/09 11:10 PM
moparmarks Offline
moparmarks  Offline
70/2 the caliper mounts on the back of the spindle and 73/4 it mounts on the front. Can't remember for sure if 73/4 is the pin style like 70/2 but I think it is.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: disc brake spindle question - b body [Re: DoctorDiff] #183073
01/03/09 11:12 PM
01/03/09 11:12 PM
moparmarks Offline
moparmarks  Offline
Was thinking that A's were shorter but guess not.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: disc brake spindle question - b body [Re: moparmarks] #183074
01/03/09 11:14 PM
01/03/09 11:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Caliper mount holes are the same on all knuckles. The (tall) knuckles are just swapped left to right on the newer B,F,M,J,R bodies.
Re: disc brake spindle question - b body [Re: DoctorDiff] #183075
01/03/09 11:16 PM
01/03/09 11:16 PM
moparmarks Offline
moparmarks  Offline
So you can just swap sides to have rear mount calipers?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: disc brake spindle question - b body [Re: moparmarks] #183076
01/03/09 11:22 PM
01/03/09 11:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, I run the caliper mounts toward the rear when using '73 and newer disc brakes on a car equipped with a pre '70 sway bar. This requires custom length hoses, however.
Re: disc brake spindle question - b body [Re: DoctorDiff] #183077
01/04/09 10:02 AM
01/04/09 10:02 AM
NY NY
3
NY NY
thanks everyone who has replied, this has been very helpful.
regarding the above comment, does the height of "B" body spindle change from 70-2 and 73+?
i have the 73+ spindles and want to confirm want to confirm that they will be a direct replacement for the 70-2 "B" drum spindle.
thanks, mike
Re: disc brake spindle question - b body [Re: 340duster340] #183078
01/04/09 12:06 PM
01/04/09 12:06 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The 73 spindles are "Taller" if they are from a B body car.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: disc brake spindle question - b body [Re: hemi71x] #183079
01/04/09 01:25 PM
01/04/09 01:25 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
If you use a taller spindle, does it effect wheel size, 14" or 15" or does that only come into play when deciding which size rotor you want to use?
Re: disc brake spindle question - b body [Re: Suregrip391] #183080
01/04/09 01:54 PM
01/04/09 01:54 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
The '73 Charger SE I had came from the factory with 14" wheels.
Re: disc brake spindle question - b body [Re: Suregrip391] #183081
01/04/09 03:07 PM
01/04/09 03:07 PM
hemi71x Offline
hemi71x  Offline
You need to use 15 inch wheels if you use the 11 3/4 inch diameter rotors.
Then you would need the larger caliper mounts from the later 70's Cordobas, Magnums, St. Regis, Furys,Chargers, whether they are the pin type, or slider type.
Just depends on what type of caliper that you want to use.
Re: disc brake spindle question - b body [Re: 340duster340] #183082
01/04/09 06:07 PM
01/04/09 06:07 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Re: disc brake spindle question - b body [Re: John_Kunkel] #183083
01/04/09 10:23 PM
01/04/09 10:23 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
So who do we believe on the 73 up B body spindles, I have heard they can be dangerous with an earlier car swap.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: disc brake spindle question - b body [Re: mopargem] #183084
01/05/09 12:36 AM
01/05/09 12:36 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I’m going with Richard Ehrenberg’s opinion which is dead set against using the taller spindles on pre-73 B-bodies. Some say it is not necessary, but I rather error on the side of factory suspension geometry than not.
Remember, this is Richard Ehrenberg of the “Green Brick” fame. He knows how to set up a Mopar suspension for performance.
Read more at this Mopar Action Tech article:Disc-O-Tech
Re: disc brake spindle question - b body [Re: mopargem] #183085
01/05/09 02:50 AM
01/05/09 02:50 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
73 up F,M,J and B are fine for the swap.
Where did you "hear" it was dangerous? Have you ever actually known of someone having issues with the swap? I havent and neither has anyone I know who has done it or knows someone else who has. You'd think if it was such a dangerous thing it would be well documented with accident reports and such, but its not. Go figure
I'm working on another brake swap in the shop now, a 74 Satellite disc set-up installed on a 72 Demon
